1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Upcoming procServ release: please test systemd support
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 13 May 2019 16:59:26 +0200
Dear all,
I am about to release a new version of procServ, which incorporates a whole bunch of features and improvements related to systemd integration. Most importantly:
  • PID file is written also when in foreground mode
  • New "oneshot" mode that exits the server when the child exits
  • Comprehensive set of tools to generate systemd and conserver configuration files for procServ-run service instances (e.g. IOCs)
If you consider yourself a stakeholder, please check out the current master branch at
and test if these things work for you.
Any feedback is highly appreciated!
Thanks a lot to Michael Davidsaver, Hinko Kocevar and Klemen Vodopivec for their valuable contributions!
Cheers,
~Ralph
Prev: EPICS June 2019: deadline coming up Ralph Lange via Tech-talk
Next: Re: Channel Access implementation for Siemens S71500 PLCs Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: EPICS June 2019: deadline coming up Ralph Lange via Tech-talk
Next: Using PVUtil to get PV's value when PV name is input as string in CSS Tyler Lemon via Tech-talk
ANJ, 20 May 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
