1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: phoebus evaluation
From: "Steven M. Hartman via Tech-talk" <[email protected]>
To: Pierrick M Hanlet <[email protected]>
Date: Tue, 14 May 2019 15:08:05 -0400
> On May 14, 2019, at 2:46 PM, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
> Does Phoebus us the EPICS_CA_ADDR_LIST environment variable?
These preferences are set via a configuration file, typically settings.ini, which is passed on the command line (or wrapper script).
See:
https://phoebus-doc.readthedocs.io/en/latest/preferences.html
Steven Hartman
[email protected]
phoebus evaluation Pierrick M Hanlet via Tech-talk
Prev: phoebus evaluation Pierrick M Hanlet via Tech-talk
Next: Re: RES: Pmac Slits Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Next: Should drvAsynIPPortConfigure print an error when device is not connected? Paduan Donadio, Marcio via Tech-talk
ANJ, 14 May 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
