Totally forgot about this issue. Same issue here with Asyn 4.34 and stream 2.8.8, we started facing this issue with stream 2.8.8. I think when we used 2.7.7c
it was reporting disconnected devices.
Best Regards,
Abdalla.
Hello, all.
When calling drvAsynIPPortConfigure on the IOC, shell passing an IP of a disconnected device, no message is print on the IOC shell. Is there a way to configure
it?
Thank you,
Márcio
Márcio Paduan Donadio
| Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w:
slac.stanford.edu
- RE: Should drvAsynIPPortConfigure print an error when device is not connected? Mark Rivers via Tech-talk
- Should drvAsynIPPortConfigure print an error when device is not connected? Paduan Donadio, Marcio via Tech-talk
Re: RES: Pmac Slits giles.knap--- via Tech-talk
Request for Response of Projects that Use EPICS bob dalesio via Tech-talk
<2019>
<2019>
ANJ, 15 May 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
