The problem was that the iocsh arguments were being passed by taking the address of an expression, rather than a variable. This is not allowed in VS2010.
I have fixed the problem and pushed to master on Github.
Sent: Friday, May 17, 2019 8:41 PM
To: Mark Rivers
Cc: [email protected]; Zimoch Dirk (PSI)
Subject: RE: asyn 4-35 does not compile on Windows 10 (VS 2019)
Asyn 4.35 does not compile on Visual Studio 2010. {I had too many windows opened}
But, it does compile on the Visual Studio 2019 CE, v16.0.4
-K
-----Original Message-----
Sent: Friday, 17 May 2019 3:34 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected]; Zimoch Dirk (PSI) <[email protected]>
Subject: Re: asyn 4-35 does not compile on Windows 10 (VS 2019)
It compiles fine on VS2015 (and VS2017 I believe)
Sent from my iPhone
On May 17, 2019, at 3:15 PM, Gofron, Kazimierz <[email protected]<mailto:[email protected]>> wrote:
I am having problems compiling asyn 4-35 (and current version of master) on Windows 10 with Visual Studio 2019 Community Edition. Problem is specific to windows since asyn-4-35 compiles on debian 7/8/9 and ubuntu 18.
C:\epics\support\asyn>make
make[1]: Entering directory 'C:/epics/support/asyn/asyn'
perl -CSD C:/epics/base/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'C:/epics/support/asyn/asyn/O.windows-x64'
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/epics/support/ipac/include -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include -c ../../asyn/drvAsynSerial/drvAsynIPPort.c
drvAsynIPPort.c
c:\epics\support\asyn\asyn\drvasynserial\drvasynipport.c(462) : warning C4267: 'function' : conversion from 'size_t' to 'int', possible loss of data .....
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/epics/support/ipac/include -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include -c ../../asyn/miscellaneous/asynInterposeDelay.c
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(216) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(220) : error C2059: syntax error : '}'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation
make[2]: *** [C:/epics/base/configure/RULES_BUILD:235: asynInterposeDelay.obj] Error 2
make[2]: Leaving directory 'C:/epics/support/asyn/asyn/O.windows-x64'
make[1]: *** [C:/epics/base/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: Leaving directory 'C:/epics/support/asyn/asyn'
make: *** [C:/epics/base/configure/RULES_DIRS:84: asyn.install] Error 2 ==========================================================================================
There is a similar error in asyninterposeecho.c, when compiling with -sj> make -sj
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(190) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(193) : error C2059: syntax error : '}'
ParamValWrongType.cpp
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(202) : fatal error C1903: unable to recover from previous error(s); stopping compilation
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation paramVal.cpp
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeEcho.obj] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeDelay.obj] Error 2 ParamValValueNotChanged.cpp asynPortDriver.cpp asynPortClient.cpp devAsynOctet.c
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(326) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(746) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(751) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(136) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(144) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(157) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(796) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
The source lines indicate the Visual Studio does not interpret 2nd set of "{"
/* register asynInterposeEcho*/
static const iocshFuncDef asynInterposeEchoFuncDef =
{"asynInterposeEcho", 2, (const iocshArg *[]) {
&(iocshArg) { "portName", iocshArgString },
&(iocshArg) { "addr", iocshArgInt },
/* register asynInterposeDelay*/
static const iocshFuncDef asynInterposeDelayFuncDef =
{"asynInterposeDelay", 3, (const iocshArg *[]) {
&(iocshArg) { "delay(sec)", iocshArgDouble },
Cheers,
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
- asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
- Re: asyn 4-35 does not compile on Windows 10 (VS 2019) Mark Rivers via Tech-talk
- RE: asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
Controls Engineer Position at NSLS-II (Brookhaven National Lab) Tian, Yuke via Tech-talk
Phoebus on Raspberry Pi 3b+ 김재우 via Tech-talk
<2019>
2025
<2019>
2025
