Note that in your gcc command -I is followed immediately by -MM, rather than by an include directory. This suggests a problem with configure/RELEASE, since it should probably be the location of EPICS base.
Sent from my iPhone
On May 20, 2019, at 1:16 PM, Madden, Timothy J. via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
I am building medm on rhel7. Medm is already installed, but when typing into text input fields, it will not accept
entry. caput to the PV works. Strange. I assume that there are mismatched libraries on the OS and whatever
medm was built with. I have seen this very problem on windows boxes.
So when building, I yum installed all the packeages from the medm website, https://epics.anl.gov/extensions/medm/index.php
I am using this linux:
Linux csi357421.aps.anl.gov<http://csi357421.aps.anl.gov> 3.10.0-957.10.1.el7.x86_64 #1 SMP Thu Feb 7 07:12:53 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
I am using base 3 15 6
I get these errors during make, when trying to make printutils. See below. Any ideas?
Tim Madden
bash-4.2$
bash-4.2$ make
make -C ./printUtils install
make[1]: Entering directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
T_A=linux-x86_64 install
make[2]: Entering directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils/O.linux-x86_64'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF xwd2ps.d ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF xwd.d ../xwd.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF utilPrint.d ../utilPrint.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF ps_utils.d ../ps_utils.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF pUtils.d ../pUtils.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -MM -MF getopt.d ../getopt.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I -c ../getopt.c
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
collect2: error: ld returned 1 exit status
make[2]: *** [getopt.o] Error 1
make[2]: Leaving directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils'
make: *** [printUtils.install] Error 2
- Re: Building MEDM on linux rhel7 Madden, Timothy J. via Tech-talk
- Building MEDM on linux rhel7 Madden, Timothy J. via Tech-talk
<2019>
2025
<2019>
2025
