1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning 101
To: Hinko Kocevar <[email protected]>
Date: Thu, 23 May 2019 10:37:32 +0000
Hi Hinko,
My first response would be to use the sscan record. But I need more explanation of what you mean by “timing system with precision triggering and timestamping”.
Sent from my iPhone
> On May 23, 2019, at 4:12 AM, Hinko Kocevar via Tech-talk <[email protected]> wrote:
> Imagine an EPICS developer with no experience in working with (coordinated) scanning application.
> The sub-units, of the system in need of scanning feature, include timing system with precision triggering and timestamping, 1 to several axes of motion, control of HV bias and 1 to several channels of data acquisition. You can assume that the (low-level) EPICS modules supporting the hardware are under my control already, I'm interested in orchestrating the scan using above constituents.
> What would be preferred approach to tackle this subject with EPICS in 2019?
> TIA,
> Hinko
Re: Scanning 101 Hinko Kocevar via Tech-talk
Prev: Ip kernel mbuf starvation on RTEMS 4.11 Antonio Lucio via Tech-talk
Next: Re: registerRecordDeviceDriver.obj unresolved external symbols Thomas, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Scanning 101 Hinko Kocevar via Tech-talk
Next: Re: Scanning 101 Hinko Kocevar via Tech-talk
ANJ, 25 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
