1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Scanivalve DTS units
From: "Evans, Richard K. \(GRC-H000\) via Tech-talk" <[email protected]>
To: Eric Norum <[email protected]>
Date: Wed, 22 May 2019 23:13:38 +0000
Excellent. Thank you!
Sent: Wednesday, May 22, 2019 5:26 PM
To: Evans, Richard K. (GRC-H000) <[email protected]>
Cc: [email protected]
Subject: Re: Scanivalve DTS units
It’s likely that StreamDevice will work — there’s an introductory tutorial at https://epics.anl.gov/modules/soft/asyn/R4-23/HowToDoSerial/HowToDoSerial_StreamDevice.html
StreamDevice documentation is at http://epics.web.psi.ch/software/streamdevice/
On May 22, 2019, at 2:15 PM, Evans, Richard K. (GRC-H000) via Tech-talk <[email protected]> wrote:
Hello,
I have twenty-two (x22) 64-Channel thermocouple measurement systems made by a company called Scanivalve Corp [0]. Specifically, each unit is a Scanivalve model DTS-4050-TX-64 [1,2]. These units provide the front-end signal conditioning for 64 thermocouples (of all types) and produce the fully processed temperatures of each channel as engineering unit data via a TCP/IP connection [3]. I would like to develop an EPICS control system for these units to initiate the start and stop of the units and to record their digital output over a tcp/ip channel.
My question is - Is there anyone in the EPICs community who can give me some basic pointers about  how to develop the needed EPICs module(s) assuming I understand the TPC/IP commands required and how the data returned is encoded? I would be very grateful for some help getting started.
Thank you,
/Rich
- Richard Evans, NASA GRC - Plum Brook Station
  ©216.973.4398
Scanivalve DTS units Evans, Richard K. (GRC-H000) via Tech-talk
Re: Scanivalve DTS units Eric Norum via Tech-talk
Prev: Re: Scanivalve DTS units Eric Norum via Tech-talk
Next: Re: registerRecordDeviceDriver.obj unresolved external symbols Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Scanning 101 Hinko Kocevar via Tech-talk
ANJ, 23 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
