1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: UDP Warnings (VME and Linux) - Subnet wide
From: "Sullivan, Joseph via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 24 May 2019 21:16:03 +0000
Hello,
The following warning messages are appearing periodically (~2hrs) on all the EPICs IOC's (VxWorks and Linux - base-3.14.12.3) on a beamline here at the APS - (base-3.14.12.3).
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 169.254.0.2:3956 ignored
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 169.254.132.146:3956 ignored
Eventually the CAS-Event processes fail (after a day or so). A reboot brings everything back and the sequence starts over.
This happened after the IOCs where brought up after a shutdown period.
Is this a network issue (someone on the CA ports that should not be) or should I look at the CA Clients (medm)?
Thanks for any help.
Joe
Joseph Sullivan
[email protected] <> 630-252-8657
Advanced Photon Source
APS Xray Science Division
Beamline Controls & Data Acquisition Group
Re: UDP Warnings (VME and Linux) - Subnet wide Mark Rivers via Tech-talk
Re: UDP Warnings (VME and Linux) - Subnet wide Johnson, Andrew N. via Tech-talk
Prev: Re: registerRecordDeviceDriver.obj unresolved external symbols Johnson, Andrew N. via Tech-talk
Next: Re: UDP Warnings (VME and Linux) - Subnet wide Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Ip kernel mbuf starvation on RTEMS 4.11 Antonio Lucio via Tech-talk
ANJ, 24 May 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
