1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pmac driver bug
From: "giles.knap--- via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Davis, Mark" <[email protected]>
Date: Thu, 30 May 2019 07:47:45 +0000
Thanks, Mark,
I will roll a fix into the next release.
Sent: 29 May 2019 19:04:39
To: [email protected]; Knap, Giles (DLSLtd,RAL,LSCI)
Subject: pmac driver bug
To Giles and other interested parties,
I found another bug in the pmac driver (version 2-4-10):
The section of code in the pmacAxis::home() function that is
conditionally compiled based on the macro REMOVE_LIMITS_ON_HOME does not
check for the PMAC_CID_POWER CID value, so when using a Power Brick
controller it simply logs an error (if enabled) and exits.
The older version of the driver I was using had the definition of the
PMAC_CID_POWER macro commented out, so the offending section of code was
not included and it would just send the home command regardless of what
type of controller you have.
For now, I commented this macro out in the newer version to get the same
behavior as the older one.
Mark Davis
NSCL/FRIB
Control Systems Software Engineer
[email protected]
Re: pmac driver bug Davis, Mark via Tech-talk
Prev: RE: devSup driver development differences between base 3.14 and 3.15 Abdalla Ahmad via Tech-talk
Next: RE: devSup driver development differences between base 3.14 and 3.15 Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: pmac driver bug Davis, Mark via Tech-talk
Next: Re: pmac driver bug Davis, Mark via Tech-talk
ANJ, 30 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
