1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: updated download link for rsync-dist (from talk at EPICS Meeting 2019)
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: Goetz Pfeiffer <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Jun 2019 17:26:34 -0500
On 06/12, Johnson, Andrew N. wrote:
> I think that's an Argonne-specific issue, I can get to the documentation URL from my phone but only when I'm not connected through Argonne's network. Using curl -v my workstation shows this, which I don't claim to understand:
> tux% curl -v https://goetzpf.bitbucket.io/rsync-dist
> * About to connect() to proxy XXXX.anl.gov port XXXX (#0)
> *   Trying XXXX...
> * Connected to XXXX.anl.gov (XXXX) port XXXX (#0)
> * Establish HTTP proxy tunnel to goetzpf.bitbucket.io:443
> > CONNECT goetzpf.bitbucket.io:443 HTTP/1.1
> > Host: goetzpf.bitbucket.io:443
> > User-Agent: curl/7.29.0
> > Proxy-Connection: Keep-Alive
> < HTTP/1.0 200 Connection established
> * Proxy replied OK to CONNECT request
> * Initializing NSS with certpath: sql:/etc/pki/nssdb
> *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
>   CApath: none
> * NSS error -12263 (SSL_ERROR_RX_RECORD_TOO_LONG)
> * SSL received a record that exceeded the maximum permissible length.
> * Closing connection 0
> curl: (35) SSL received a record that exceeded the maximum permissible length.
> I filed a ticket for the problem earlier, haven't heard back about it yet though.
Hmm, indeed; thanks for the info!
I actually get a different failure:
$ curl -Iv https://goetzpf.bitbucket.io/rsync-dist
*   Trying 146.139.125.18...
* TCP_NODELAY set
* Connected to goetzpf.bitbucket.io (146.139.125.18) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/cert.pem
  CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* error:1400410B:SSL routines:CONNECT_CR_SRVR_HELLO:wrong version number
* stopped the pause stream!
curl: (35) error:1400410B:SSL routines:CONNECT_CR_SRVR_HELLO:wrong version number
Investigating a little more, I noticed that goetzpf.bitbucket.io does
not seem to be resolving correctly from the ANL network:
$ host goetzpf.bitbucket.io
goetzpf.bitbucket.io is an alias for honeypot.anl.gov.
honeypot.anl.gov has address 146.139.125.18
So, ANL is hijacking DNS again and messing things up. :-(
Of course, resolving goetzpf.bitbucket.io off-site works correctly.
Lewis
updated download link for rsync-dist (from talk at EPICS Meeting 2019) Goetz Pfeiffer via Tech-talk
Re: updated download link for rsync-dist (from talk at EPICS Meeting 2019) J. Lewis Muir via Tech-talk
Re: updated download link for rsync-dist (from talk at EPICS Meeting 2019) Johnson, Andrew N. via Tech-talk
Prev: Re: updated download link for rsync-dist (from talk at EPICS Meeting 2019) Johnson, Andrew N. via Tech-talk
Next: Re: Asyn 4-35 IOC upgrade misbehavior Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Next: [AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
ANJ, 14 Jun 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
