1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: RE: [AsynDriver] getAddress and callbacks
To: 'Joao Afonso' <[email protected]>
Date: Fri, 14 Jun 2019 17:23:27 +0000
Hi Joao,
Ø  In those cases, the IOC will get the address from "pasynManager->getAddr()", and not from getAddress(), which breaks the program.
Ø  (for ex. in paramList::octetCallback())
The callbacks are traversing a linked list of clients that have registered for callbacks.  This is typically asyn device support, but it is not limited to that.  That linked list is created outside of asynPortDriver by asynManager when each client registers for callbacks.   For example, this is the abbreviated code in devAsynInt32.c
    pasynUser = pasynManager->createAsynUser(processCallback, 0);
    pPvt->pasynUser = pasynUser;
    status = pasynEpicsUtils->parseLink(pasynUser, plink,
               &pPvt->portName, &pPvt->addr, &pPvt->userParam);
    status = pasynManager->connectDevice(pasynUser, pPvt->portName, pPvt->addr);
    status = pPvt->pint32->registerInterruptUser(
               pPvt->int32Pvt,pPvt->pasynUser,
               pPvt->interruptCallback,pPvt,&pPvt->registrarPvt);
So that pPvt->pasynUser has been connected to a particular port and address, typically specified in the OUT in INP link in the record.  The asynPortDriver callback functions are retrieving the address stored in that pasynUser in the linked list node via pasynManager->get_addr().
    pnode = (interruptNode *)ellFirst(pclientList);
    while (pnode) {
        asynInt32Interrupt *pInterrupt = (asynInt32Interrupt *) pnode->drvPvt;
        pasynManager->getAddr(pInterrupt->pasynUser, &address);
        /* If this is not a multi-device then address is -1, change to 0 */
        if (address == -1) address = 0;
        if ((command == pInterrupt->pasynUser->reason) &&
            (address == addr)) {
I don’t see how it could have access to the address that your getAddress() method is generating?
Sent: Friday, June 14, 2019 11:51 AM
Cc: [email protected]
Subject: [AsynDriver] getAddress and callbacks
Hello Mark,
Sorry to bother you, I have a question regarding the usage of this function:
I have a use case where it is useful to override asynPortDriver::getAddress() to get a custom reason and address.
These values are chosen previously by drvUserCreate(), and stored in pasynUser->drvUser and pasynUser->reason.
This seems to work well for gets and puts, but not when a callback for for a "I/O Intr" record is executed.
Is there a way to make the callbacks also use the custom asynPortDriver::getAddress() value?
Thank you in advance,
Joao
RE: [AsynDriver] getAddress and callbacks Mark Rivers via Tech-talk
[AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
Prev: [AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
Next: RE: [AsynDriver] getAddress and callbacks Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 14 Jun 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
