1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question about Sphinx tables
From: "tom.cobb--- via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Jun 2019 15:33:33 +0000
Hi Mark,
I suspect the lack of borders is inherited from the theme CSS. You can override the CSS in a few different ways:
https://stackoverflow.com/a/32079202
The way I have done it in the past (assuming you want to keep the same theme) is to use a theme_override.css file like this one:
https://github.com/dls-controls/malcolmjs/blob/master/docs/source/_static/theme_overrides.css
You will need to place this override file somewhere and list the place in conf.py:
html_static_path = ['_static']
I won’t guess at precisely what CSS overrides are needed, as I normally just use the developer tools in the browser to inspect the page and prod things until it looks right…
As a side note, I recently discovered list-tables, which work well if you have tables that mix short labels and long descriptions:
.. list-table::
    :widths: 30, 70
    :align: center
    :header-rows: 1
    * - Option
      - Description
    * - Download Plot as PNG
      - Provides the ability to download a snapshot of the chart for use outside
        the user interface.
    * - Zoom
      - Allows you to select a rectangular bounding box around a feature of
        interest and zoom in on it.  The level of zoom dynamically adjusts
        according to the size of the bounding box (smaller box = higher zoom)
        with X and Y axes dynamically scaling to reflect the granularity of the
        resulting plot.  Note that while zoomed updates to the selected area
        pause, instead presenting a snapshot at the time of zoom.
    * - Pan
      - Provides the ability to pan the chart through horizontal and vertical
        axes.  Note that unlike **Zoom** options panning does not pause
        automatic updates, thus when panning back through time the plot may
        appear blank.
Tom
From: [email protected] <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: 17 June 2019 15:44
To: [email protected]
Subject: Question about Sphinx tables
Folks,
Thanks to a lot of work by Stuart Wilkins the areaDetector documentation is moving from pure HTML to .rst files processed with Sphinx and hosted at https://areadetector.github.io/master/index.html.
I have a question about how to make the tables look better.
I have a simple CSV table:
.. csv-table::
   :header: Record names, Record types, GenICam features
   :delim: |
   FrameRate, FrameRate_RBV | ao, ai | FrameRate or FrameRateAbs
   FrameRateEnable, FrameRateEnable_RBV | bo, bi| FrameRateEnable or FrameRateEnabled
   TriggerSource, TriggerSource_RBV | mbbo, mbbi | TriggerSource
   TriggerOverlap, TriggerOverlap_RBV | mbbo, mbbi | TriggerOverlap
   TriggerSoftware | bo | TriggerSoftware
   ExposureMode, ExposureMode_RBV | mbbo, mbbi | ExposureMode
   ExposureAuto, ExposureAuto_RBV | mbbo, mbbi | ExposureAuto
   GainAuto, GainAuto_RBV | mbbo, mbbi | GainAuto
   PixelFormat, PixelFormat_RBV | mbbo, mbbi | PixelFormat
Sphinx generates this HTML for the beginning of the table:
<table border="1" class="docutils">
<colgroup>
<col width="33%" />
<col width="33%" />
<col width="33%" />
</colgroup>
<thead valign="bottom">
<tr class="row-odd"><th class="head">Record names</th>
<th class="head">Record types</th>
<th class="head">GenICam features</th>
</tr>
</thead>
<tbody valign="top">
<tr class="row-even"><td>FrameRate, FrameRate_RBV</td>
<td>ao, ai</td>
<td>FrameRate or FrameRateAbs</td>
Note that it has border=”1”, so the table should have borders.  However, it actually renders (in Chrome) as shown in the attachment, i.e. with no borders.
I manually edited the HTML to change it to “border=5” and that made no difference, there are still no borders.
If I remove the class=”docutils” from the table line, then it does render differently (closely packed columns), but there are still no borders.
Can anyone tell me what is causing this behavior?  I suspect it may be related to these lines near the beginning of the generated HTML file:
    <link rel="stylesheet" href="" type="text/css" />
Do those style sheets override the settings for tables?  I looked at those files and I did not see anything obvious for the table borders.
Is there a way to get borders?
Question about Sphinx tables Mark Rivers via Tech-talk
Prev: procServ v2.8.0-rc2 available for testing and feedback Ralph Lange via Tech-talk
Next: RE: Question about Sphinx tables Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Question about Sphinx tables Mark Rivers via Tech-talk
ANJ, 17 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
