Hi Torsten,
The only issue I am aware of with inserting a Moxa in to the
communications link is the one I discovered a few months ago that had to
do with the fact that the StreamDevice interface doesn't handle
responses that are broken up in to multiple packets when using I/O Intr
mode (see TechTalk messages from 3/18/19 with subject "StreamDevice
Processing Issue")
Unless the SmartMotor controller returns responses > 112 bytes and the
asyn interface has a similar issue with multi-packet responses, I don't
see why a Moxa would cause any problems. In fact, we have used the
vendor's software just fine with the Moxa configured as a virtual/remote
serial port connected to the motor/controller's RS-232 interface.
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 6/18/2019 10:16 AM, Torsten Bögershausen wrote:
> (Re-adding tech-talk)
> Hej Mark & Mark,
> that doesn't seem to be good news -
> The model 1 driver will not work with a Moxa at all.
> Unless I am wrong, we need a model 3 driver (to be written),
> when a controller connected through a Moxa is used.
> /Torsten
> On 18/06/19 16:04, Mark Rivers wrote:
>> Hi Mark,
>> What Torsten says is true for Model 2 and Model 3 motor drivers.
>> However the SmartMotorSrc driver is an old Model 1 driver, so the
>> driver is not derived from asynPortDriver and it only has the single
>> asyn port to the underlying drvAsynIPPort.
>> The OUT field syntax for Model 1 drivers is:
>> field(OUT,"#C$(C) S$(S) @")
>> where $(C) is the card number, and $(S) is the signal number. So for
>> the first axis on the first controller it would be
>> field(OUT, "#C0 S0 @")
>> Mark
>> -----Original Message-----
>> From: [email protected] <[email protected]>
>> On Behalf Of Torsten Bögershausen via Tech-talk
>> Sent: Tuesday, June 18, 2019 6:45 AM
>> To: Mark Davis <[email protected]>; Davis, Mark
>> <[email protected]>; [email protected]
>> Subject: Re: Animatics SmartMotor setup
>> Hej Mark,
>> you need 2 asyn ports, one for the motorRecord to talk to your
>> "Animatics SmartMotor" asynMotorDriver.
>> The second one to let the "Animatics SmartMotor" asynMotorDriver talk
>> to the real hardware.
>> We call them "MCU1" and "MC_CPU1", better suggestions are welcome.
>> A simplified setup is here:
>> ## The db file:
>> record(motor,"$(PREFIX)$(MOTOR_NAME)")
>> field(DESC,"$(DESC)")
>> field(DTYP,"asynMotor")
>> field(OUT,"@asyn($(MOTOR_PORT),$(AXIS_NO))")
>> ##st.cmd
>> epicsEnvSet("ASYN_PORT", "MC_CPU1")
>> epicsEnvSet("MOTOR_NAME", "IOC:m1")
>> epicsEnvSet("MOTOR_PORT", "MCU1")
>> epicsEnvSet("AXIS_NO", "1")
>> drvAsynIPPortConfigure("$(ASYN_PORT)","$(IPADDR):$(IPPORT)",0,0,0)
>> EthercatMCCreateController("$(MOTOR_PORT)", "$(ASYN_PORT)",
>> "$(NUMAXES)", "200", "1000")
>> EthercatMCCreateAxis("$(MOTOR_PORT)", "$(AXIS_NO)",)
>> I hope that hopes a little bit.
>> /Torsten
>> On 18/06/19 13:11, Davis, Mark via Tech-talk wrote:
>>> Can anyone provide an example of how to setup and use an Animatics
>>> SmartMotor?
>>> From what I could figure out looking at the code, I expect it is
>>> something along these lines:
>>> # For a connection via a Moxa Ethernet-to-serial adapter:
>>> drvAsynIPPortConfigure("TapeStation", "192.168.137.99:4001")
>>> # SmartMotorSetup(maxCtlrCount, pollRate) SmartMotorSetup(1, 5)
>>> # SmartMotorConfig(cardNum, "asynPortName") SmartMotorConfig(0,
>>> "TapeStation")
>>> And then the motor record would look something like this:
>>> record(motor, "MyMotor")
>>> field(DTYP, "SmartMotor")
>>> field(OUT, "@0 TapeStation ????")
>>> Is that even close? The one I am most unsure of is what to use for
>>> the OUT value in the motor record.
>>> Mark Davis
>>> NSCL/FRIB
- Animatics SmartMotor setup Davis, Mark via Tech-talk
- Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Re: Animatics SmartMotor setup Davis, Mark via Tech-talk
<2019>
2025
RE: Animatics SmartMotor setup Mark Rivers via Tech-talk
<2019>
2025
