1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Beckhoff BK9000 support survey
From: Davide Marcato via Tech-talk <[email protected]>
To: "Dunning, Michael" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 27 Jun 2019 09:41:17 +0200
Hello,
at LNL-INFN (Italy) we are using the same beckhoff modules using the epics modbus module. This works well enough for us, but some modules have internal register that cannot be accessed directly (register communication). For this reason we developed a asynPortDriver interface to be able to access the internal registers of the KL2541 stepper motor module as part of the whole motor record support for that module.
We would be interested in any improved interface to these modules.
Thank you,
Davide
On 27/06/19 2:17 AM, Dunning, Michael via Tech-talk wrote:
At SLAC we use Beckhoff bus terminals quite extensively because they
are inexpensive and reliable, but unfortunately don't yet have a
common epics support solution.  We have at least three versions of
support which were developed independently.
One version uses only the epics modbus module.  This has no driver so
requires less maintenance, but makes setting up IOCs more time
consuming and results in a lot of code duplication.
Another version uses asynPortDriver and some custom modbus code.  This
is designed to make setting up IOCs easier, but requires maintenance
of the driver code.
Another uses custom epics device support.  This requires writing
device support for each bus terminal, and has resulted in a pretty
ugly codebase.  This is our least favored solution going forward.
A typical installation would be a BK9000 bus coupler plus several
analog and/or digital I/O modules (e.g. KL2114, KL1104, KL3172,
KL3314), communicating over ethernet using Modbus TCP.
Before we settle on a solution, we'd like to see what everyone else is
doing.  Any responses would be helpful.
Thank you,
Mike
Michael Dunning
SLAC National Accelerator Laboratory
2575 Sand Hill Road
Menlo Park, CA 94025
(650) 926-5200
Davide Marcato
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 Legnaro (PD) - ITALY
Phone: +39 0498068439
Mail: [email protected]
Beckhoff BK9000 support survey Dunning, Michael via Tech-talk
Prev: Re: Running EPICS R3.14.12.7 in RTEMS 4.11 emilio.perez-juarez--- via Tech-talk
Next: RE: [EXTERNAL] Beckhoff BK9000 support survey Pearson, Matthew R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: Beckhoff BK9000 support survey Mark Rivers via Tech-talk
ANJ, 27 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
