Hi Hinko,
There is a memory leak in the version of the decimation filter I sent out, due to my not completely understanding the filter API (and to a similar bug in the sync filter). An IOC that runs this filter much may eventually run out of memory. Please apply this
change to my original code to fix the problem:
diff --git a/src/std/filters/decimate.c b/src/std/filters/decimate.c
index d34884e..502422f 100644
--- a/src/std/filters/decimate.c
+++ b/src/std/filters/decimate.c
@@ -63,6 +63,8 @@ static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl) {
if (i++ == 0)
passfl = pfl;
+ else
+ db_delete_field_log(pfl);
if (i >= my->n)
i = 0;
- Andrew
On 6/10/19 10:46 AM, Andrew Johnson wrote:
On 6/10/19 8:34 AM, Hinko Kocevar wrote:
FYI, Andrew, I have not changed a single line of code for the decimate.c, when I deployed IOC for the system that uses this new filter. Can we expect it to appear in next EPICS base code so that we do not have to maintain it outside the vanilla sources?
I added documentation and test code and
created a merge request for it last week for the 3.15 branch of Base, so unless the other core developers object it should make it into the next releases of both 3.15.x and 7.0.x. IIRC I only made one minor change to the code to make it slightly more robust,
without changing any functionality.
- Andrew.
Complexity comes for free, Simplicity you have to work for.
- Re: Camonitor with client dictated update rate Hinko Kocevar via Tech-talk
- Camonitor with client dictated update rate Hinko Kocevar via Tech-talk
- Re: Camonitor with client dictated update rate William Layne via Tech-talk
- Re: Camonitor with client dictated update rate Matt Newville via Tech-talk
- Re: Camonitor with client dictated update rate Emanuele Laface via Tech-talk
- Re: Camonitor with client dictated update rate Johnson, Andrew N. via Tech-talk
Re: Re:Re: .opi from CSS to Phoebus Hinko Kocevar via Tech-talk
Re: [EXTERNAL] Beckhoff BK9000 support survey Jeong Han Lee via Tech-talk
<2019>
2025
<2019>
2025
ANJ, 01 Jul 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
