1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question regarding a waveform record and writeOctet
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 2 Jul 2019 15:39:16 +0000
Ah OK I missed setting the nActual in the function as you suggested. Once I added that the error went away.
Thanks again,
-Jakub
From: [email protected] <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Tuesday, July 2, 2019 11:30 AM
To: [email protected]
Subject: Fwd: Question regarding a waveform record and writeOctet
Forgot to cc tech-talk again
Sent from my iPhone
Begin forwarded message:
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: July 2, 2019 at 10:29:44 AM CDT
To: "Wlodek, Jakub" <[email protected]<mailto:[email protected]>>
Does your driver's writeOctet correctly set nActual?
Sent from my iPhone
On Jul 2, 2019, at 10:15 AM, Wlodek, Jakub via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi all,
I have run into an issue with a waveform record I added to one of my IOCs. It simply stores a filename, and there is a writeOctet function that catches writing to it and makes sure that the filepath is valid. This all seems to work OK - the filepath is checked correctly, and the code is able to access it as expected later on. It all works, aside from the following error message displayed in the IOC shell:
2019/07/02 10:47:37.910 13SIM1:{SimDetector-Cam:1}CV1:FilePath devAsynOctet::writeIt requested 22 but sent 94456003460432 bytes
The entered filepath does in fact have a length of 22 bytes, but I have no idea where the 94456003460432 came from, especially since the remainder of the code seems to be reading the entered string correctly. After further testing, I wrote to the filepath PV again, and got:
2019/07/02 10:47:46.220 13SIM1:{SimDetector-Cam:1}CV1:FilePath devAsynOctet::writeIt requested 23 but sent 0 bytes
Once again, the filepath was processed correctly and worked fine in my code, and it was 23 characters long. After some searching I identified the printout to be in the asyn library here: https://github.com/epics-modules/asyn/blob/187b0a03e5d2cdd696c4203147aebe83ef049cb9/asyn/devEpics/devAsynOctet.c#L636.
My record definition looks as follows:
record(waveform, "$(P)$(R)FilePath"){
    field(PINI, "YES")
    field(DTYP, "asynOctetWrite")
    field(INP,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))NDCV_FILEPATH")
    field(FTVL, "CHAR")
    field(NELM, "256")
    field(autosaveFields, "VAL")
record(waveform, "$(P)$(R)FilePath_RBV"){
    field(DTYP, "asynOctetRead")
    field(FTVL, "CHAR")
    field(NELM, "256")
    field(SCAN, "I/O Intr")
If anyone could help me identify what might be causing this issue it would be much appreciated.
Regards
-Jakub Wlodek
Question regarding a waveform record and writeOctet Wlodek, Jakub via Tech-talk
Fwd: Question regarding a waveform record and writeOctet Mark Rivers via Tech-talk
Prev: EtherIP for P3-550 DiMonte, Nicholas via Tech-talk
Next: Fwd: cross-compiling (kind of) with Buildroot Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: Question regarding a waveform record and writeOctet Mark Rivers via Tech-talk
Next: EtherIP for P3-550 DiMonte, Nicholas via Tech-talk
ANJ, 02 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
