1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Docker Container
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 10 Jul 2019 17:30:16 +0200
Hey Ralph and Lucas,
thanks for the information. I remember to had problems running multiple IOCs on the same host and thought it was due to both IOC tried to bind to the same ports. Maybe there was a different problem. I only tried it once and that was actually by accident.
I will test using the "host" network for my docker containers. This would also solve the minor problem, that the UDP broadcasts are not forwarded from docker's virtual bridge network to the physical one. And as Lucas pointed out, I don't need an additional CA-gateway container...
Best regards,
Florian
On 7/10/19 4:47 PM, Lucas Russo via Tech-talk wrote:
Hi Florian,
I'm using the script Ralph mentioned on [1] for Debian hosts and it works ok. I'm running a few dozen IOCs on some of my hosts.
Cheers!
Lucas
On Wed, Jul 10, 2019 at 11:35 AM Ralph Lange via Tech-talk <[email protected]> wrote:
Hi Florian,
On Wed, 10 Jul 2019 at 14:17, Florian Feldbauer via Tech-talk <[email protected]> wrote:
My only concern is, if I want to run multiple IOCs on the same host. (Never actually did that). Don't I have to set individual CA Server ports for each IOC? PVaccess sets it's port dynamically if the default port is already in use.
This is a very common mode of operation, and: no, you don't have to apply specific settings to IOCs.
The only caveat: If clients do not use broadcasts for name resolution, only one IOC will receive the name resolution request. (I.e. these clients only "see" the IOC that was started last.) The good news: there is a well-tested workaround for that issue; see [1].
I have seen setups between a few and hundreds of IOCs running on a single host.
Cheers,
~Ralph
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
EPICS Docker Container Florian Feldbauer via Tech-talk
Re: EPICS Docker Container Lucas Russo via Tech-talk
Re: EPICS Docker Container Florian Feldbauer via Tech-talk
Re: EPICS Docker Container Ralph Lange via Tech-talk
Prev: Re: EPICS SNL Stack Size Benjamin Franksen via Tech-talk
Next: Fwd: Problems with stream device 2.8.8 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Docker Container Lucas Russo via Tech-talk
Next: re:EPICS Docker Container Jack Harper - UKRI STFC via Tech-talk
ANJ, 10 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
