1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: monitoring field device
From: Pierrick M Hanlet via Tech-talk <[email protected]>
To: William Layne <[email protected]>
Date: Tue, 16 Jul 2019 21:36:37 +0000
Thanks, I was thinking of doing something similar, but this is a bit more elegant.
Cheers,
Pierrick
On 7/16/19 4:12 PM, William Layne wrote:
Without knowing some more more details. If you have written the driver support you can always restart a epicsTimer when you receive valid data.
Then when the timer expires, have it set a PV associated with this loss of comm.
Casey
On Tue, Jul 16, 2019, 5:02 PM Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
I have a field device connected via ethernet to a soft ioc (v7 and
sl7.6).  The device
loses communication (we're still waiting for a firmware fix).  In the
meantime, is
there some way to configure the alive record, or something like it, to
monitor this
connection?
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
monitoring field device Pierrick M Hanlet via Tech-talk
Re: monitoring field device William Layne via Tech-talk
Prev: Re: monitoring field device William Layne via Tech-talk
Next: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
