1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SmarAct MCS2 ASCII-based IOC
From: "Stubbs Scott Allen \(PSI\) via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 19 Jul 2019 11:58:27 +0000
Hi Kevin,
Thank you for the note!  That is indeed a recent development.  A few observations:
- Our driver does not use the EPICS motor record (this could be positive or negative, depending on your use case)
- From the README it appears David's driver does not support changing positioner type and use of rotary stages, which the PSI driver should
- I was not aware of the step size (nm -> pm) difference from the MCS - I will be changing the default 'slope' accordingly, thanks...
	==> Though according to the MCS2 manual rotary stages typically use nano-degree steps
- And of course, the fact that David's driver seems to have been tested is certainly an advantage over ours :)
Of course, I am sure both modules will be improved over time.  When we do eventually get a test unit, I will make sure to let the community know.
Best,
Scott
__________________________________________
Scott Stubbs
Controls Group
Paul Scherrer Institut
5232 Villigen PSI
Schweiz
Telefon: +41 56 310 21 65
E-Mail: [email protected]
-----Original Message-----
Sent: Mittwoch, 17. Juli 2019 17:45
To: Stubbs Scott Allen (PSI) <[email protected]>; [email protected]
Subject: Re: SmarAct MCS2 ASCII-based IOC
David Vine recently wrote an asyn motor driver for the MCS2 that uses ASCII commands instead of the vendor's C++ library.  The driver can be found in the motorSmarAct module:
   https://github.com/epics-motor/motorSmarAct
The README for the MCS2 support is here:
https://github.com/epics-motor/motorSmarAct/blob/master/smarActApp/src/README.SmarActMCS2
Kevin
On 7/17/19 4:31 AM, Stubbs Scott Allen (PSI) via Tech-talk wrote:
> Dear Tech-talkers,
> As it seems there is no fully ASCII-'byte stream' based IOC for the
> SmarAct MCS2 (at least not available publicly) I am pleased to present
> our first attempt at one using StreamDevice.  I began developing it
> based on our MCS IOC when we believed we would need to integrate the
> MCS2 for a particular project. As we purchased the MCS in the end, and
> we have no MCS2 units for testing, our development has also stopped
> for the time being.
> Comments, forks, additions and/or fixes welcome. Note that while we
> have put some effort in converting commands and EPICS records from the
> MCS (e.g. positioner types, amplifier voltage.) this is a completely
> untested IOC and still based around our internal PSI build system.
> However, the db/ and cfg/ files can be considered universal.  If I get
> permission from SmarAct I will publish their full documentation here
> as well.
> Also, a special thank you to SLAC colleagues who gave me a starting
> point for the protocol file =)
> Link:
> https://github.com/paulscherrerinstitute/smaract_mcs2/
> Greetings from Switzerland,
> Scott
> Scott Stubbs
> Controls Group
> 5232 Villigen PSI
> Schweiz
SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Re: SmarAct MCS2 ASCII-based IOC Peterson, Kevin M. via Tech-talk
Prev: RE: USBTMC Device can not autoConnect Mark Rivers via Tech-talk
Next: RE: USBTMC Device can not autoConnect Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SmarAct MCS2 ASCII-based IOC Peterson, Kevin M. via Tech-talk
Next: USBTMC Device can not autoConnect Christopher Herrmann via Tech-talk
ANJ, 19 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
