Hi Andrew,
I've filtered for packets coming from a specific IP address, so I know which IOC is sending it.
I hadn't considered the possibility that the problem is in a sequencer program. A quick check of the relevant sequencer programs shows that these channels are referenced there as well as in the main database file. So... I will do some further investigation...
Hi Mike,
How do you know what client is requesting those names? My guess is it may be a sequence program (or maybe a PV named in an access security file) running on the same IOC which hasn't been given the right prefix.
The 'dbcar' command lists the IOC's dbCa links, and can confirm or deny that it's a database link (use
dbcar "*", 0/1/2 to see increasing amounts of info). You'll need to use the sequencer commands seqShow and seqChanShow to check for unconnected channels for your sequence programs, I forget what the arguments are to seqChanShow but I think you give
it a program name and "-" to see only disconnected channels. There is also a similar 'ascar <level>' command for reporting CA connections if you're using access security.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
-- Mike Westfall
Control Systems Software Engineer
- Channel Access and channel name weirdness Michael Westfall via Tech-talk
- Re: Channel Access and channel name weirdness Johnson, Andrew N. via Tech-talk
RE:Compress Record with input from partial Waveform GAGET Alexis via Tech-talk
Start OPIs from command line interface Tong Zhang via Tech-talk
<2019>
Compress Record with input from partial Waveform Bruno Martins via Tech-talk
<2019>
ANJ, 22 Jul 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
