Hello everyone,
Recently, I noticed one of my IOCs consuming a lot more
memory right after IOC startup (from linux "top" command, RES
field, which I know it's not a good estimate sometimes, but
still...) after upgrading it from EPICS base 3.14.12.6 to
3.15.6. All of the other EPICS modules was kept in the same
version:
asyn: R4-35
areaDetector: R3-6
Even with other IOCs, areaDetector ADSimDetector, for
instance, the memory consumption after IOC startup was way
higher than before. For example:
EPICS 3.14 ADSimDetector: RES = 356502 MiB
EPICS 3.15 ADSimDetector: RES = 48613 MiB
After doing some debugging and memory profiling I saw that
the ADSimDetector IOC running with EPICS 3.15 had the "VMLck"
field from /proc/<pid>/status with:
VmLck: 4586544 kB
And the IOC running EPICS 3.14 had:
VmLck: 0 kB
Taking a look at the Release Notes there was a mention of "mlockall"
being moved to some other place ("Moved mlockall()
into its own epicsThread routine", "Changes made between
3.15.3 and 3.15.4")
I changed the "dbThreadRealtimeLock"
variable from 1 (default) to 0 and the memory
consumption dropped back to ~48613 MiB. Even after running the
IOC for some time, doing some large acquisitions, the memory
consumption was not close to the 356502 MiB.
Can anyone help me understand if this is somewhat expected?
And wouldn't it be better to have the variable dbThreadRealtimeLock with the
default value of 0, instead of 1?
Cheers and Regards,
Lucas
