1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: epics base compilation for ARM Cotex-A53 (ARM64bit)
From: "Ha, Kiman via Tech-talk" <[email protected]>
Date: Fri, 26 Jul 2019 01:53:38 +0000
Hello all,
I am trying to install epics base to Zynq Ultrascal+ FPGA and local compile same as the Linux host, It has quad ARM Cotex-A53 core.
My approach is a local compilation instead of cross-compile.
Does anyone have experience an EPICS base (3.16.x and 7.x) compilation for ARM64 core ?
OS : Debian GNU/Linux 10.0
Core Architects : aarch64
Kernel : 4.19.0
I typed make and got below messages.
fpga@debian10-zcu102:~/epics/base-7.0.2.2/configure$ make
../src/tools/EpicsHostArch.pl: Architecture 'aarch64-linux-gnu-thread-multi' not recognized
../configure/CONFIG:58: ../configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target '../configure/os/CONFIG..Common'.  Stop.
fpga@debian10-zcu102:~/epics/base-7.0.2.2/configure$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-6' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --disable-libphobos --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 8.3.0 (Debian 8.3.0-6)
Kiman
Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Michael Davidsaver via Tech-talk
Prev: Re: OPIs from command line - Re: Tech-talk Digest, Vol 13, Issue 309 Tong Zhang via Tech-talk
Next: Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
