1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: Alarm system setup
From: "Shroff, Kunal via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, enum riz <[email protected]>
Date: Thu, 1 Aug 2019 16:13:06 +0000
Hi Enum,
A new alarm server based on kafka is available. Not only is it better performing it is easier to configure and run.
It also allows you to import existing beast alarm configuration files.
Here is a link to the talk Kay gave about it.
Cheers,
Kunal
From: [email protected] <[email protected]> on behalf of enum riz via Tech-talk <[email protected]>
Sent: 24 July 2019 02:38
To: [email protected] <[email protected]>
Subject: Alarm system setup
Hi Kay
Can you help me how to execute
AlamConfigTool -plugincutomization/path/to/settings.ini -root demo -file demo.xml -import
in your presentation 2012,April at SLAC. As there is no exe file for this AlarmConfigTool and AlarmServer.
How i will configure the server and client on the same system for Alarm?
thanx
enum
Alarm system setup enum riz via Tech-talk
Prev: Call for EPICS October 2019 collaboration meeting Farnsworth, Richard via Tech-talk
Next: Re: Help required Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: Alarm system setup enum riz via Tech-talk
Next: EPICS 3.15 mlockall()/dbThreadRealtimeLock high memory usage Lucas Russo via Tech-talk
ANJ, 01 Aug 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
