1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: spec epics_caget not working
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: "Miceli, Antonino" <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Mon, 5 Aug 2019 19:47:43 -0700
On 8/5/19 1:12 PM, Johnson, Andrew N. via Tech-talk wrote:
> That isn't possible, AFAIK the firewall rules only know that some packets are being sent between some local and remote IP address+port, it doesn't know what the program is that's doing that I/O. Both Spec and caget use the CA client library which will perform identically given the same set of EPICS_CA_* environment variables.
Though it is likely not relevant in this case.
FYI.  Linux iptables rules can consider sending process UID and GID.
cf. the --uid-owner match.
spec epics_caget not working Miceli, Antonino via Tech-talk
Re: spec epics_caget not working Jennings, Guy via Tech-talk
Re: spec epics_caget not working Mark Rivers via Tech-talk
Re: spec epics_caget not working Johnson, Andrew N. via Tech-talk
Prev: Re: Question about EPICS7 + QSRV Michael Davidsaver via Tech-talk
Next: Re: [motorPIGCS2] can't turn on servo state of PI E-712 Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: spec epics_caget not working Johnson, Andrew N. via Tech-talk
Next: Question about EPICS7 + QSRV Florian Feldbauer via Tech-talk
ANJ, 06 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
