1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [motorPIGCS2] can't turn on servo state of PI E-712
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
Date: Wed, 7 Aug 2019 02:14:47 +0000
Hi Kevin,
> I've emailed Steffen Rau, the author of the PIGCS2 support...
Thanks a lot.
I don't change the terminators set by PIasynController::PIasynController, excerpt:
    status = pasynOctetSyncIO->setInputEos(pAsynCom, "\n", 1);
    status = pasynOctetSyncIO->setOutputEos(pAsynCom, "", 0);
The PIGCSPiezoController.cpp(.h) seems incomplete or only targets a specific model.
For example, the following method implementations are not suitable for my case.
    getReferencedState  set pAxis->m_homed to 1,
    initAxis  calls setServo(pAxis, 1),
    getStatus  just set homing, negLimit, and posLimit to 0.
I'm modifying PIGCSPiezoController, though the progress is slow because of few experience.
Allow me to provide devices' detailed info:
    PI E-712.1AM  Predefined System Configuration, which contains:
         PI E-712.R4  Chassis
         PI E-712.N1  Digital Processor Module
         PI E-711.AM5A: Amplifier modules for NEXLINE®, -250 V to +250 V, for drives with sensor.
         N-111K077 NEXLINE OEM Piezo Stepping Actuator
The photo:
https://www.dropbox.com/s/77xhg9x0a9f7y2g/2019-06-26%2014.50.05%20PI%20E-712.jpg?dl=0
Best regards.
LiangChih Chiang
Email:[email protected]
Beamline Group
National Synchrotron Radiation Research Center (NSRRC)
寄件者: Peterson, Kevin M. <[email protected]>
寄件日期: 2019年8月6日 下午 11:56
收件者: Chiang, Liang-Chih [江良志]; [email protected]
主旨: Re: [motorPIGCS2] can't turn on servo state of PI E-712
LiangChih,
Those terminators look correct.  Your observation that the
PIGCSPiezoController class assumes an absolute sensor is likely the
cause of the errors.  I've emailed Steffen Rau, the author of the PIGCS2
support, for guidance on which parts of PIGCSPiezoController and
PIGCSMotorController apply to the E-711.AM5A.
Kevin
My working hours may not be your working hours. Please do not
feel obligated to reply outside of your normal work schedule.
On 8/5/19 8:12 PM, Chiang, Liang-Chih [江良志] via Tech-talk wrote:
> Hi Kevin,
> epics> asynOctetGetOutputEos("PIE712")
> epics> asynOctetGetInputEos("PIE712")
> "\n"
> Allow me to repeat the devices again:
>      PI E-712.1AM Digital Motion controller.
> I found the following comment in motor-R6-11/motorApp/PIGCS2Src/PIGCSPiezoController.h
>      Main difference to motor controllers is the usage of absolute sensors.
> But PI E-711.AM5A uses incremental encoder.
> Best regards.
> LiangChih Chiang
> Beamline Group
[motorPIGCS2] can't turn on servo state of PI E-712 Chiang, Liang-Chih [江良志] via Tech-talk
RE: [motorPIGCS2] can't turn on servo state of PI E-712 Allan Serra Braga Bugyi via Tech-talk
RE: [motorPIGCS2] can't turn on servo state of PI E-712 Chiang, Liang-Chih [江良志] via Tech-talk
Re: [motorPIGCS2] can't turn on servo state of PI E-712 Peterson, Kevin M. via Tech-talk
Prev: Re: [motorPIGCS2] can't turn on servo state of PI E-712 Peterson, Kevin M. via Tech-talk
Next: comment a field with a macro Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: AW: [motorPIGCS2] can't turn on servo state of PI E-712 Chiang, Liang-Chih [江良志] via Tech-talk
ANJ, 07 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
