New releases of the following areaDetector modules are now available.
ADGenICam R1-0
ADAravis R1-0
ADSpinnaker R2-0
ADGenICam is a new EPICS areaDetector driver for GenICam cameras. It is a base class that actual drivers inherit from. These actual drivers implement the GenICam standard in vendor-specific SDKs.
https://areadetector.github.io/master/ADGenICam/ADGenICam.html
The following drivers currently derive from this base class:
ADAravis which supports any GigE, 10GigE, or USB-3 GenICam camera on Linux. It is based on aravis. It is intended to replace the existing areaDetector aravisGigE driver.
https://areadetector.github.io/master/ADAravis/ADAravis.html
ADSpinnaker which supports GigE, 10GigE, and USB-3 GenICam cameras from FLIR/Point Grey on Linux and Windows. It uses the FLIR/Point Grey Spinnaker SDK. It is intended to replace the existing areaDetector ADPointGrey driver.
https://areadetector.github.io/master/ADSpinnaker/ADSpinnaker.html
ADVimba which supports GigE, 10GigE, and USB-3 GenICam cameras from AVT/Prosilica on Linux and Windows. It uses the Allied Vision's Vimba SDK. It is intended to replace the existing areaDetector ADProsilica driver. https://github.com/areaDetector/ADVimba
This driver is not yet ready to be released and does yet have documentation.
Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Re: [EXTERNAL] procServ v2.8.0 available Vodopivec, Klemen via Tech-talk
<2019>
motor R7-1 released Peterson, Kevin M. via Tech-talk
<2019>
