Hi all
I talked to Dirk Zimoch about the connection drop issue. He noticed an even worse behavior. The first message after the timeout is lost w/o hope. Only the second message causes the logger to notice the connection loss and triggers the re-establishment. But, the 2nd message is still dropped. The next message (3rd) will get through.
IMHO, this is something that should be fixed at the source not at the receiver side.
@logstash: We use v7.2.0 right now.
logstash input:
input {
tcp {
port => 1234
type => 'caputlog'
@grok:
This is what I use as grok filter. Notice, we prefix the messages with the IOC-name. If you don't do this, remove '%{IOC}' obviously.
filter {
if [type] == "caputlog" {
grok {
match => {
"message" => "^%{IOC} %{TS} %{CLIENT} %{USER} %{PV} %{NEW} %{OLD}?(%{MINMAX})?"
pattern_definitions => {
"TS" => "(?<timestamp>%{MONTHDAY}-(?i)%{MONTH}-%{YEAR} %{TIME})"
"IOC" => "%{IPORHOST:ioc}"
"CLIENT" => "%{IPORHOST:client}"
"USER" => "%{USERNAME:user}"
"PV" => "(?<pv>\S+)"
"NEW" => "new=(%{NUMBER:newval}\s+%{QUOTEDSTRING:newstring}|(%{NUMBER:newval})|(%{QUOTEDSTRING:newstring}))"
"OLD" => "old=(%{NUMBER:oldval}\s+%{QUOTEDSTRING:oldstring}|(%{NUMBER:oldval})|(%{QUOTEDSTRING:oldstring}))"
"MINMAX" => "( min=%{NUMBER:min}\s+max=%{NUMBER:max})?"
mutate {
convert => {
"pv" => "string"
"newval" => "float"
"oldval" => "float"
"min" => "float"
"max" => "float"
This should match:
TEST-IOC 19-Aug-2019 00:51:36 client.psi.ch user P:PV.CAL new=1 old=0 min=0 max=1
TEST-IOC 19-Aug-2019 00:51:36 client.psi.ch user P:PV.CAL new=1 "on" old=0 "off"
The last line is for future implementation of enum logging.
best
Niko
Paul Scherrer Institute
Dr. Niko Kivel
Forschungsstrasse 111
WBGB/014
5232 Villigen PSI
Switzerland
phone: +41 56 310 2226
email: [email protected]
Sent: Saturday, August 17, 2019 16:13
To: johnson, andrew n.; j. lewis muir; Kivel Niko (PSI)
Cc: tech-talk
Subject: Re: connection timeout between ioc and logstash
Hi all,
I've test the tcp_keep_alive option, unfortunately, it didn't work either. The difference is the IOC doesn't prompt error info when timeout. I can tell that the time of timeout is half an hour(28 minutes later is ok, 31 minutes later is abnormal). Then, logstash can never receive new message except I restarting the IOC. It's no use to restart logstash. The logstash configuration I use as follow:
input {
tcp {
host => "${EPICS_IOC_LOG_INET:10.1.236.30}"
port => "${EPICS_IOC_LOG_PORT:7011}"
id => "ioclog-${EPICS_IOC_LOG_PORT:7011}"
codec => "line"
tcp_keep_alive => true
filter {
grok {
MONTHNAM => "(?:Jan|Feb|Mar|Apr|May|Jun|Jul|Aug|Sep|Oct|Nov|Dec)"
TIMESTAMP => "%{MONTHDAY}-%{MONTHNAM}-%{YEAR} %{TIME}"
PV => "\S+"
# named_captures_only => true
# The following string must be all one line, one space between parts
match => { "message" => "%{TIMESTAMP:timestamp} %{HOSTNAME:client} %{USER:user} %{PV:pv} new=%{NUMBER:new:float} old=%{NUMBER:old:float}" }
# date {
# # Extract the timestamp from the message as a proper logstash
# # timestamp field type, but since the IOC's clock might not be
# # accurate we don't replace the locally generated @timestamp.
# match => ["timestamp", "dd-MMM-yy HH:mm:ss"]
# locale => "en"
# target => "@ioctimestamp"
output {
# elasticsearch {
# hosts => "10.1.236.30:9200"
# index => "caputlog-%{+YYYY-MM-dd}"
stdout { codec => rubydebug }
It can't parse correctly if I added "(?: min=%{NUMBER:min} max=%{NUMBER:max})?" to the end of grok match part. It would work only if there was no burst. I haven't found a solution for this.
-----原始邮件-----
发件人:"Johnson, Andrew N." <[email protected]>
发送时间:2019-08-17 00:43:01 (星期六)
收件人: "吴煊" <[email protected]>, "j. lewis muir" <[email protected]>, "kivel niko (psi)" <[email protected]>
抄送: tech-talk <[email protected]>
主题: Re: connection timeout between ioc and logstash
On 8/16/19 10:22 AM, 吴煊 via Tech-talk wrote:
I simplly followed the instruction written by Andrew Johnson https://events01.synchrotron.org.au/event/85/contributions/2601/attachments/689/997/5_06_Logstash_for_IOCs.pdf A thread named "IOClog" in May 2th 2019 had mentioned this.
I've installed logstash 7.2 in a linux box. I configured 'caPutLogInit "10.1.236.30:7011", 1' in st.cmd. The configuration file for logstash is fellowing:
input {
tcp {
codec => "line"
output {
file {
path => "/log/ioc/putlog-%{+YYYY-MM-dd}.json"
That's all the configuration. I can not figure out who closed the connection, but I think logstash may closed it, because iocLogServer will not. I'll try the tcp_keep_alive option next and to see it would work or not.
Apparently the default setting for the TCP SO_KEEPALIVE option can be different on different OSs, and the logstash configuration file I presented had not been widely tested (I've been running logstash on MacOS here). The iocLogServer code does explicitly set SO_KEEPALIVE in its acceptNewClient() routine so I think that logstash option will be the correct solution to this problem ― please let tech-talk know your results.
By the way, I found that the grok filter in the example file is not correct for logstash 7.2
I developed those regular expressions using http://grokdebug.herokuapp.com/ and logstash 6.3.2 and am currently running 7.0.0, but we're not doing put-logging here yet. If you have a fix for logstash 7.2 I would be interested in seeing it.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: connection timeout between ioc and logstash Zimoch Dirk (PSI) via Tech-talk
- connection timeout between ioc and logstash 吴煊 via Tech-talk
- Re: connection timeout between ioc and logstash J. Lewis Muir via Tech-talk
- RE: connection timeout between ioc and logstash Kivel Niko (PSI) via Tech-talk
- Re: Re: connection timeout between ioc and logstash 吴煊 via Tech-talk
- Re: connection timeout between ioc and logstash Johnson, Andrew N. via Tech-talk
- Re: connection timeout between ioc and logstash 吴煊 via Tech-talk
<2019>
2025
<2019>
2025
