1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: pvput and enum (EPICS 7.0.3)
To: 'Alfio Rizzo' <[email protected]>
Date: Wed, 21 Aug 2019 15:42:56 +0000
This is a known problem with writing enum fields with pvPut in 7.0.3.
See this core-talk thread.
https://epics.anl.gov/core-talk/2019/msg00810.php
From: [email protected] <[email protected]> On Behalf Of Alfio Rizzo via Tech-talk
Sent: Wednesday, August 21, 2019 8:24 AM
To: [email protected]
Subject: pvput and enum (EPICS 7.0.3)
HI
I am running a simple ioc with a bi record
record(bi, "$(user):SimulationMode") {
  field(DESC, "Operational Status")
  field(ZNAM, "NO")
  field(ONAM, "YES")
  field(PINI, "YES")
  field(VAL,  "0")
And I was wondering why I cannot change its value (0/1) via pvput
unless I use –p ca option.  Instead pvmnonitor and pvget are working fine.
If I put this line on the record definition
field(INP , "$(user):SimulationMode.RVAL")
Then I can change the .RVAL via pvput and then VAL will change accordingly
Why does pvput work only with Scalar and not with Enum field ?
Is this a feature ?
Thanks
Best
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
pvput and enum (EPICS 7.0.3) Alfio Rizzo via Tech-talk
Prev: pvput and enum (EPICS 7.0.3) Alfio Rizzo via Tech-talk
Next: Is anyone building AreaDetector with Sumo? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 21 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
