1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: PINI set to YES but no VAL field in the record definition
From: Hinko Kocevar via Tech-talk <[email protected]>
Date: Thu, 22 Aug 2019 03:40:28 +0000
What happens if the record (I.e. longout) has PINI set to YES, but there is no VAL field set? Is 0 used as initial value? Does it make sense to have PINI=YES in such cases?
Hinko
Re: PINI set to YES but no VAL field in the record definition Mark Rivers via Tech-talk
Prev: Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
Next: Re: PINI set to YES but no VAL field in the record definition Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: RE: Is anyone building AreaDetector with Sumo? Ivashkevych, Oksana via Tech-talk
ANJ, 22 Aug 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
