1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Sumo test
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 23 Aug 2019 08:17:45 +0200
the discussion about sumo triggered me to take a look at this tool to figure
out if it can helm me to solve a problem I currently have. I need to setup a
procedure to roll out a set of EPICS modules for a project that will be
installed also off site by inexperienced persons. And looking at the
documentation sumo would exactly do what I need. I would configure my IOC
application using sumo and the locally installed modules. Then I would roll
out the application together with the sumo config files and it would be a few
well documented steps to get the IOC compiled an running.
Currently I have a set of shell scripts, a set of patches for the
configuration files and a Makefile to do the job. But as the configuration
files change with every new release, I need to create the patches on a regular
basis. That step I would like to get rid off.
So I installed all EPICS modules I need, together with base in the directory
structure needed by sumo (modules/src/<module name>/<module version>).
Then I ran sumo-scan on the modules directory to get the configuration. All my
modules where clonedout from github and the latest tag was checked out. Much
to my surprise sumo-scan put all modules as "path" type, only areaDetector sub
modules (besides aravisGigE) where detected as "git" repositories.
Looking with "sumo-scan -t" at what is done during the process, Isee a small
difference between the areaDetector and all other modules:
git -C .../modules/src/areaDetector/3-7/ADSupport status --porcelain
returns nothing, while e.g.
git -C .../modules/src/iocStats/3.1.15 status --porcelain
returns
 M configure/RELEASE
Which I needed to change to be able to define all the depended modules.
So here I#m stuck. Do I realy have to create the dependency file by hand?
Any tips and ideas welcome!
Regards
Jörn Dreyer
Re: Sumo test Mark Rivers via Tech-talk
Prev: Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
Next: Re: Sumo test Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: RE: CameraLink and ADPCO Mark Rivers via Tech-talk
ANJ, 23 Aug 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
