1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: MouseListener and MouseEvent on Intensity Graph in CSS
From: Apeksha Chipade - UKRI STFC via Tech-talk <[email protected]>
Date: Wed, 11 Sep 2019 14:09:47 +0000
Hi all,
I am working on a way to draw a line on an intensity graph in CSS BOY. I have a Jython script which can track the image co-ordinates.
Now, I need to have a way by which I can capture the mouse events on the intensity graph like click and release.
I am a novice in writing Jython scripts. I came across this thread (https://epics.anl.gov/tech-talk/2017/msg00775.php) and dropped the idea of using pynput package.
I have created a MouseListener to listen to pressed event, but it seems I cannot get the mouse events. Have I missed anything?
This is my script:
from org.csstudio.opibuilder.scriptUtil import PVUtil, ConsoleUtil
from org.csstudio.swt.widgets.figures.IntensityGraphFigure import IPixelInfoProvider
from org.eclipse.draw2d import MouseEvent
from org.eclipse.draw2d import MouseListener
from org.eclipse.ui import PlatformUI
from org.eclipse.swt.events import MouseWheelListener
class MyPixelInfoProvider(IPixelInfoProvider):
                #### Provide custom information for each pixel.
                def getPixelInfo(self, xIndex, yIndex, xCoordinate, yCoordinate, pixelValue):
                                result = "My index is (" + str(xIndex) + ", " + str(yIndex) + " )"
                                ConsoleUtil.writeInfo(result)
                                return result
widget.getFigure().addPixelInfoProvider(MyPixelInfoProvider())
class MyListener2(MouseListener):
                def mousePressed(self, event):
                                ConsoleUtil.writeInfo("down")
my_listener2 = MyListener2()
widget.getFigure().addMouseListener(my_listener2)
Many thanks in advance.
Kind Regards,
Apeksha Chipade
Re: MouseListener and MouseEvent on Intensity Graph in CSS Kasemir, Kay via Tech-talk
Prev: RE: Driver for Smargon gniometer James.OHea--- via Tech-talk
Next: Re: MouseListener and MouseEvent on Intensity Graph in CSS Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Perkin Elmer drivers for Windows 10 Mark Rivers via Tech-talk
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
