1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer]
To: Ashish Sharma <[email protected]>
Date: Thu, 12 Sep 2019 01:55:10 +0000
Hi Ashish,
> Camera is directly connected to PC using 1m long CAT5E cross cable. In actual implementation I am planning to use a long cable (4-5m) as the beam line is separated from control room. So, I expect a further bad throughput.
You almost certainly don’t need to use a crossover cable. Modern network hardware will negotiate to work with a normal cable.
Extending the distance from 1m to 4-5m will have no impact on performance. In fact 100m should not impact performance.
 > MEDM shows Acquisition Frame Rate of ~71 fps, Processed Frame rate of ~61 fps
ImageJ shows Frame Rate of ~48-49 fps
If you look at the technical specs for that camera here it shows that the maximum frame rate in mono mode is 78 frames/s and 22 frames/s in color mode:
https://m.boxcn.net/shared_item/https%3A%2F%2Fflir.boxcn.net%2Fs%2Fvuzvy3z0r5aw797v4vameck5ieipkim0/view/418605669392
Please send a screenshot of your medm screen. I don’t know what you mean by Processed Frame rate in areaDetector. I already explained why ImageJ rate can be less.
>In RGB:
MEDM shows Acquisition Frame Rate of ~26 fps, and Processed frame rate of ~20 fps. ImageJ shows frame rate of ~12-15 fps
That is actually about the maximum frame rate according to the data sheet.
> Frame drop is less in RGB naturally due to lesser frame rate.
That is not true. It is packets that are dropped, not frames, and in color mode the packet rate is 3X that in mono mode.
> when I use SpinView software of FLIR (in Windows) I can see that camera is working very fast > 70 fps (even in RGB mode)
That is not possible in RGB mode unless you have configured it to use Bayer mode. Here is why. The camera is 1440x1080 pixels. If the frame rate is 70 frames/s in color mode then the data rate is 70 * 1440 * 1080 * 3 byes/s. That is 311 MB/s which is 3 times the theoretical maximum speed of GigE, so it is impossible. Please send a screen shot if you still think it is true.
Sent from my iPhone
On Sep 11, 2019, at 7:42 PM, Ashish Sharma <[email protected]<mailto:[email protected]>> wrote:
Hi Mark,
Sorry for late response.
I was able to change color mode to RGB1 without any segmentation failure. Problem was that I was just changing CC1 property and not the Color Mode from camera's main MEDM landing page. As you mentioned YUV isn't working. So, I think dumped core logs are not required anymore.
How many frames/s are being dropped?  Is the camera on a shared network, or a private network directly connected to the PC?  If it is on a shared network then you need to worry about other traffic on the network interfering with the camera.
Camera is directly connected to PC using 1m long CAT5E cross cable. In actual implementation I am planning to use a long cable (4-5m) as the beam line is separated from control room. So, I expect a further bad throughput. Future possibility of being put in a shared network can not be ruled out. Please suggest some measures upon this. Camera does not need to be up, running and acquiring all the time.
In Grayscale:
In RGB:
Here, I would like to say that, when I use SpinView software of FLIR (in Windows) I can see that camera is working very fast > 70 fps (even in RGB mode) in both acquisition as well as processing mode. But the same is not seen in AreaDetector. Why is so?
My laptop is dual boot with Windows 10 and Ubuntu 16.04. AreaDetector is running in Ubuntu.
Please help.
Thanks
Ashish
----- Original Message -----
From: "Mark Rivers" <[email protected]<mailto:[email protected]>>
To: "Ashish Sharma" <[email protected]<mailto:[email protected]>>, "Mark S. Engbretson" <[email protected]<mailto:[email protected]>>
Cc: "tech-talk" <[email protected]<mailto:[email protected]>>
Sent: Monday, September 9, 2019 7:26:59 AM
Hi Ashish,
The Stats plugin also shows that you blew through all your buffers so you might be dropping frames somewhere.
Are you looking at "Dropped Arrays : 14429" to understand this phenomenon.
I have not changed any setting for obtaining these Stats.
Yes, the dropped arrays means the Stats plugin is not keeping up.  But this is normal, and nothing to worry about.
Even after increasing buffer sizes to 8 MB, I still see many dropped frames but ImageJ shows frame rate of ~45 FPS while in MEDM it shows ~65 FPS.
ImageJ will usually show fewer frames/s than the camera is collecting.  This is because ImageJ requires CPU power to display the images.
Another problem is that, my ImageJ display only shows Grayscale images. When I change the image type from Common Plugin Window of CC1 and CC2 color mode property to either RGB1 or YUV444 or like wise, the IOC crashes showing
./start_epics: line 1:  4881 Segmentation fault      (core dumped) ../../bin/linux-x86/aravisGigEApp st.cmd
while MEDM gets disconnected showing the following error and the camera stays in acquisition mode unless I shut power down.
RGB1 should work, YUY444 will not.
Please send the following:
- The complete output when your IOC starts up.
- After the crash it will have created a core file, probably in your default working directory when you started the IOC.  Run gdb on this file as follows:
gdp <path_to_IOC_application> <core file>
Where <path_to_IOC_application> is the complete path the IOC application and <core file> is the core file that was created in the crash.
At the gdb prompt type this command:
backtrace
Send the output of gdb.
From: Ashish Sharma <[email protected]<mailto:[email protected]>>
Sent: Friday, September 6, 2019 2:26 AM
To: Mark S. Engbretson
Cc: Mark Rivers; tech-talk
Hi Mark, and Mark S.
Can you open other plot windows in medm, e.g. the cursor plots or
time-series plots in the Stats1 plugin?
It appears that your medm build is not correct or your X server is not working correctly, that window should not be blank.
Actually you were right, SCIPLOT=YES was set in ~/epics/extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86
but it was commented out in medm Makefile. Upon activation, all the plots can now be seen successfully.
medmCAExceptionHandlerCb: Channel Access Exception:
 Channel Name: Unavailable
 Native Type: Unavailable
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Message: Virtual circuit disconnect
 Context: localhost:5064
 Requested Type: TYPENOTCONN
 Requested Count: 0
 Source File: ../cac.cpp
 Line number: 1225
Please let me know if there is any other setting that I must do to make color images relayed without crashing IOC.
Thanks.
Ashish
From: "Mark S. Engbretson" <[email protected]<mailto:[email protected]>>
To: "Mark Rivers" <[email protected]<mailto:[email protected]>>, "Ashish Sharma" <[email protected]<mailto:[email protected]>>
Sent: Thursday, September 5, 2019 8:08:14 PM
Subject: RE: Image display on ImageJ not showing up. [AravisGigE,       areaDetector,   ADViewer]
-----Original Message-----
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> On
Behalf Of Mark Rivers via Tech-talk
Sent: Thursday, September 5, 2019 8:55 AM
To: Ashish Sharma <[email protected]<mailto:[email protected]>>
Cc: tech-talk <[email protected]<mailto:[email protected]>>
Hi Ashish,
NDPluginStdArrays is enabled, but still I don't get any statistical plot
in Stats1 window (image5.png - A blank histogram window can be seen).
NDPluginStdArrays does not have anything to do with the Stats1 plugin.  It
correctly, that window should not be blank.  I have never seen that.
Could you please suggest any other mode to obtain plots of pixel vs
intensity in x and y axes.
ImageJ has a nice tool for displaying live profile plots.  Draw a line
across your image with the Line tool, and then select Analyze/Plot profile,
and then press the Live button to see a live profile that updates with each
new image.
Sent: Thursday, September 5, 2019 8:04 AM
To: Mark Rivers
Cc: tech-talk
Hi Mark,
I have understood your concern and have changed it to 20e6. Meanwhile I am
following your link to mitigate problem of dropped frames.
I have another question:
while in MEDM, as per attached screenshot in image4.png (All common plugins
enabled), NDPluginStdArrays is enabled, but still I don't get any
statistical plot in Stats1 window (image5.png - A blank histogram window can
be seen).
Moreover, after camera image display my aim is to obtain the x-y intensity
plot of ROI for which when I see
https://cars.uchicago.edu/software/epics/areaDetectorViewers.html
I, found that IDL may prove to be useful. But I could not download its
virtual machine setup for linux (ubuntu 16.04 here). Could you please
suggest any other mode to obtain plots of pixel vs intensity in x and y
axes.
Thanks.
Ashish
Cc: "Mark S. Engbretson" <[email protected]<mailto:[email protected]>>, "tech-talk"
Sent: Thursday, September 5, 2019 5:56:00 PM
Hi Amish,
and set EPICS_CA_MAX_ARRAY_BYTES=2147483648.
No, you should not set it to a number that large.  My understanding is that
Channel Access server and/or client will actually allocate arrays of size
EPICS_CA_MAX_ARRAY_BYTES, so you should set it just a bit larger than your
largest image.  That is explained in the documentation link I sent you.
https://areadetector.github.io/master/ADViewers/ad_viewers.html
Sent: Thursday, September 5, 2019 7:07 AM
To: Mark Rivers <[email protected]<mailto:[email protected]>>
Cc: Mark S. Engbretson <[email protected]<mailto:[email protected]>>; tech-talk
Hi Mark,
Thanks again. Actually I also spotted all these mistakes and set
EPICS_CA_MAX_ARRAY_BYTES=2147483648. By doing so, I was able to start ImageJ
display.
I could also set NDPluginStdArrays enable from MEDM.
As per your suggestion, I shall now work on dropped frames.
Thank you very much once again.
Ashish
From: "Mark Rivers" <[email protected]<mailto:[email protected]>>2147483648
Sent: Thursday, September 5, 2019 4:23:59 PM
Hi Amish,
EPICS_BASE_LIB=/usr/local/epics/base/lib/linux-x86
EPICS_BASE=/usr/local/epics/base
EPICS_HOST_ARCH=linux-x86
EPICS_CA_ADDR_LIST=127.0.0.1
EPICS_DISPLAY_PATH=/home/pelcon/Apps/epics/modules/areaDetector/ADCore
/ADApp/op/adl
EPICS_BASE_BIN=/usr/local/epics/base/bin/linux-x86
EPICS_ROOT=/usr/local/epics
EPICS_CA_AUO_ADDR_LIST=NO
I assume these are all of your EPICS environment variables?  If so, I see 2
problems.
1) You have misspelled EPICS_CA_AUTO_ADDR_LIST, you left out the T in AUTO.
2) You have not set EPICS_CA_MAX_ARRAY_BYTES.  Set that to 20000000 (20
million) to be safe with your cameras.  The NDStdArrays plugin will not work
without that being set.  It is documented here:
https://areadetector.github.io/master/ADViewers/ad_viewers.html<https://area
detector.github.io/master/ADViewers/ad_viewers.html#epics-ad-viewer-java<http://detector.github.io/master/ADViewers/ad_viewers.html#epics-ad-viewer-java>>
These are my environment variables, still I have the errors of
duplicacy in ImageJ console. [see image3.png]
Those are actually just warnings, and they won't stop things from working
correctly, so let's ignore those for now.
One thing I also noticed is that, when I start acquiring from the
camera, a solid green LED showing acquisition is going smoothly is
visible but on IOC, I see  "Bad Frame Status: Timeout" (maybe it is
due to frame dropping in between??) [see left side of image1.png] at
regular intervals when I started the acquisition from MEDM screen [see
right side of image1.png]
In order to prevent dropped frames you need to increase some Linux network
buffer settings.  I have documented how to do that here.
https://areadetector.github.io/master/ADGenICam/ADGenICam.html#linux-usb-and
-gige-system-settings
It can also be helpful to enable Jumbo Frames on your network card. You can
do that in your Linux network system settings.
I can see that you have collected many frames OK because the
ArrayCounter_RBV on your screen shot is 4816.
Next, image1.png and image2.png you can also see ImageJ plugins being
started and No Display can be seen while the ImageJ log says everything is
working fine. Neither the camera goes in acquisition mode (no LED glows up).
Pressing Start in ImageJ only starts the ImageJ display, it does not control
the camera at all.  To start the camera you need to press Start on the medm
display.  Please send a screen shot of the main medm window after you press
Start there. What is the Image rate, i.e. frames/s?
Have you enabled callbacks on the plugins in question?  NDPluginStdArrays
or NDPluginPva for ImageJ, depending on which ImageJ plugin you are using.
NDPluginStats for the histogram plugin.  If you still have problems please
send a screen shot of those plugin screens.
You did not send the screen shot I asked for.  Please press the Plugins/All
button in medm and send a screen shot of that commonPlugins.adl screen.
I have epicsV4 installed at ~/epics/epicv4/ but I don't know whether this
is sufficient to enable NDPluginStdArrays for ImageJ. Can you please help me
on achieving this?
NDPluginStdArrays does not use epicsv4 at all, it only uses standard EPICS
Channel Access.
I am also facing trouble with ADSpinnaker IOC as it does not start from
the same template that I am using to start through aravisGigE.
I am not sure what you mean by "template" in this context?  There is an
example IOC in ADSpinnaker.
Sent: Thursday, September 5, 2019 4:02 AM
To: Mark Rivers
Cc: Mark S. Engbretson; tech-talk
Hi Mark,
Thanks for your elaborate response.
You need to set these environment variables
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST=xxx.xxx.xxx.xxx
EPICS_DISPLAY_PATH=/home/pelcon/Apps/epics/modules/areaDetector/ADCore/ADApp
/op/adl
These are my environment variables, still I have the errors of duplicacy in
One thing I also noticed is that, when I start acquiring from the camera, a
solid green LED showing acquisition is going smoothly is visible but on IOC,
I see  "Bad Frame Status: Timeout" (maybe it is due to frame dropping in
between??) [see left side of image1.png] at regular intervals when I started
the acquisition from MEDM screen [see right side of image1.png]
I have epicsV4 installed at ~/epics/epicv4/ but I don't know whether this is
sufficient to enable NDPluginStdArrays for ImageJ. Can you please help me on
achieving this?
I am also facing trouble with ADSpinnaker IOC as it does not start from the
Please help me in ADGenICam example ioc creation. If above methods don't
work out, I shall try that.
Thanks
Ashish
To: "Mark S. Engbretson" <[email protected]<mailto:[email protected]>>, "Ashish Sharma"
Sent: Wednesday, September 4, 2019 5:25:52 PM
Hi Ashish,
Message: Identical process variable names on multiple servers
These errors a coming because you have more than one network card on your
machine, and you are running both the EPICS IOC and the EPICS client (medm)
on the same machine.  This is an annoying problem with EPICS, but it is easy
to fix.
where xxx.xxx.xxx.xxx is the broadcast address of the network you want to
use for EPICS Channel Access.  It is typically the public network interface
of your machine, rather than one of the private network interfaces.  On my
machine I might have private network address of 192.168.0.1 and a public
network address of 164.54.160.202.  I set EPICS_CA_ADDR_LIST=164.54.160.255
because the netmask of the public interface is 255.255.255.0.
I have both ADGenICam and ADSpinnaker built in my system but I tried
first wiith AravisGigE after reading T. Cobb's comment that it should work
with GigEVision camera. Am I mistaken here?
I found setting up ADSpinnaker setup a bit difficult in comparison to
aravisGigE. Can you please help here?
You actually have 4 choices of drivers to use with that camera.
- aravisGigE.  This is based on the aravis package.  It runs on most any
version of Linux, and it should work fine.
- ADAravis.  This is also based on aravis, but uses the new ADGenICam base
class.  It also runs on most any version of Linux, and it should work.  It
queries camera properties more frequently than aravisGigE and so has
performance problems with some cameras because aravis does not currently
properly cache camera registers.  The aravis developer is working on this
problem.
- ADSpinnaker.  This uses the new Spinnaker SDK from FLIR.  It runs on
Windows and Linux.  The SDK is built with very recent version of gcc so they
only claim it works on Ubuntu 18.  In fact it may work on Ubuntu 16, and it
has been tested on RHEL8.
- ADPointGrey.  This uses the older FlyCap2 SDK from FLIR/Point Grey.  It
runs on Linux and Windows.  The version of the FlyCap2 SDK included in
ADPointGrey runs on RHEL7, although the more recent versions of the SDK
require Ubuntu (16 or 18?).
Still I am unable to see the ImageJ display and NX, NY, NZ still being
blank with 0.0 Frames/s. [ Duplicate issue of PV in ImageJ is still there
even after EPICS_CA_ADDR_LIST setup].
Are there any errors in the ImageJ log window?
Also the medm screens does not show any histogram etc. plots however,
it seem to acquire from camera. [I have enable SCIPLOT in medm
installation and commented out Xrtgraph]
Have you enabled callbacks on the plugins in question?  NDPluginStdArrays or
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> on
behalf of Ashish Sharma via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Wednesday, September 4, 2019 6:04 AM
To: Engbretson, Mark S.
Cc: tech-talk
Hi Mark,
Thanks for your response.
EPICS_DISPLAY_PATH setup could recognize the missing .adl files and that
error has gone but the follwing long list is still appearing as soon as I am
opening my camera link in medm,
Wed Sep 04 14:44:02 IST 2019
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:Gain", Connecting to: 169.254.0.2:5064,
Ignored: 10.1.15.37:5064
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:DataType_RBV", Connecting to:
llrf-Control.local:5064, Ignored: 10.1.15.37:5064
 Requested Count: 0
 Line number: 1308
I have both ADGenICam and ADSpinnaker built in my system but I tried first
wiith AravisGigE after reading T. Cobb's comment that it should work with
Still I am unable to see the ImageJ display and NX, NY, NZ still being blank
with 0.0 Frames/s. [ Duplicate issue of PV in ImageJ is still there even
Also the medm screens does not show any histogram etc. plots however, it
seem to acquire from camera. [I have enable SCIPLOT in medm installation and
Please help.
Thanks.
Ashish
From: "Engbretson, Mark S." <[email protected]<mailto:[email protected]>>
Sent: Wednesday, September 4, 2019 3:32:41 PM
First of all, you do not have the EPICS_DISPLAY_PATH variable set that
points to the location of the adl files in ADCore.
If you are using a FLIR camera, you should probably be using just the
GenICam and ADSpinnaker directories, not the Aravis ones.
The duplicate PV's are caused my most OS's these days having more than 1
ethercard, or virtual ethernet cards. You normally solve this by setting the
EPICS_CA_ADDR_LIST to a single ip # ( or even to 127.0.0.1) and setting
EPICS_AUTO_ADDR_LIST to NO
On Sep 4, 2019, at 04:26, Ashish Sharma via Tech-talk
<[email protected]<mailto:[email protected]><mailto:[email protected]>> wrote:
Dear all,
I am trying to configure and use FLIR BFS-PGE-16S2C-CS camera for beam
viewing application. This camera has GigEVision interface.
My system has Ubuntu 16.04, 32-bit version.
Successfully tested Acquisition app of Spinnaker SDK to capture 10 images.
I have installed AreaDetector module successfully and also configured the
aravisGigE module of areaDetector. arv-tool-0.6 successfully recognized my
camera and using the following link I was able to generate the .template
file, .edl, -feature.edl, and .adl files successfully.
http://controls.diamond.ac.uk/downloads/support/aravisGigE/0-1-9/documentati
on/doxygen/index.html
I then added the following to my st.cmd file in
aravisGigE/iocs/aravisGigEIOC/iocBoot/iocAravisGigE
aravisCameraConfig("$(PORT)", "FLIR-19308820")
dbLoadRecords("$(ARAVISGIGE)/db/FLIR-19308820.template","P=$(PREFIX),R=cam1:
,PORT=$(PORT),ADDR=0,TIMEOUT=1")
This is corresponding to my Camera ID.
then upon running ./start_epics it loads the db from template (~ 1202 PVs).
Next I installed the MEDM package successfully and ran
medm -x aravisTop.adl
It starts the top menu and when I select my camera from drop-down, (infact
any of the listed cameras), it gives following console output simultaneously
opening the control page for camera with features listed as well:
MEDM Version 3.1.14: Loading aliased fonts.................
compositeFileParse: Cannot open file
 filename: ADSetup.adl
 filename: ADPlugins.adl
 filename: ADShutter.adl
 filename: ADAttrFile.adl
 filename: ADBuffers.adl
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ArraySizeX_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ArraySizeY_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ColorMode", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ColorMode_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:AcquireTime", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:AcquireTime_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:AcquirePeriod", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:AcquirePeriod_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:NumImages", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:NumImages_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:NumImagesCounter_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ImageMode", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ImageMode_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:TriggerMode", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:TriggerMode_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:TriggerSoftware", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:Acquire", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:BinX", Connecting to: 169.254.0.2:5064,
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:TimeRemaining_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:DetectorState_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ArrayCounter", Connecting to:
 Requested Count: 0
 Line number: 1308
 Native Count: 0
 Access: Unavailable
 Host: Unavailable
 Context: Channel: "13ARV1:cam1:ArrayCounter_RBV", Connecting to:
 Requested Count: 0
 Line number: 1308
Too many exceptions [25]
No more will be handled
Please fix the problem and restart MEDM
Upon Pressing "Acquire" button, the camera link LED is constant ON and I
think it starts acquiring as well.
After that I installed ImageJ and Java on my PC and subsequently added and
complied/run the EPICS_areaDetector Plugins (i.e. EPICS AD Controller, EPICS
AD Viewer, EPICS NTNDA Viewer).
When I started EPICS AD Viewer and added my PV prefix as 13ARV1:image1: (it
is shown in green highlight) and status is 4/9/2019 14:49:51.869: Connected
to EPICS PVs OK
But on pressing Start nothing happens, 4/9/2019 14:51:23.206: Image display
started message is displayed but no display is actually started and NX, NY,
NZ and Frames/s boxes are still empty.
However, the console of ImageJ shows the following issues:
Sep 04, 2019 2:02:30 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:Over1:1:PositionX' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:02:30 PM
INFO: More than one PVs with name '13ARV1:Over1:1:PositionY' detected,
INFO: More than one PVs with name '13ARV1:Over1:1:SizeX' detected,
INFO: More than one PVs with name '13ARV1:Over1:1:SizeY' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:02:32 PM
INFO: More than one PVs with name '13ARV1:ROI1:MinX' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:MinY' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:MinX_RBV' detected,
INFO: More than one PVs with name '13ARV1:ROI1:MinY_RBV' detected,
INFO: More than one PVs with name '13ARV1:ROI1:BinX' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:BinY' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:ReverseX_RBV' detected,
INFO: More than one PVs with name '13ARV1:ROI1:ReverseY_RBV' detected,
INFO: More than one PVs with name '13ARV1:ROI1:SizeX' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:SizeY' detected, additional
INFO: More than one PVs with name '13ARV1:ROI1:ArraySizeX_RBV' detected,
INFO: More than one PVs with name '13ARV1:ROI1:ArraySizeY_RBV' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:02:34 PM
INFO: More than one PVs with name '13ARV1:Trans1:Type' detected, additional
INFO: More than one PVs with name '13ARV1:Trans1:ArraySizeX_RBV' detected,
INFO: More than one PVs with name '13ARV1:Trans1:ArraySizeY_RBV' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:02:36 PM
INFO: More than one PVs with name '13ARV1:cam1:MinX' detected, additional
INFO: More than one PVs with name '13ARV1:cam1:MinY' detected, additional
INFO: More than one PVs with name '13ARV1:cam1:MinX_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:MinY_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:SizeX' detected, additional
INFO: More than one PVs with name '13ARV1:cam1:SizeY' detected, additional
INFO: More than one PVs with name '13ARV1:cam1:ArraySizeX_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:ArraySizeY_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:MaxSizeX_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:MaxSizeY_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:BinX_RBV' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:02:37 PM
INFO: More than one PVs with name '13ARV1:cam1:BinY_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:ReverseX_RBV' detected,
INFO: More than one PVs with name '13ARV1:cam1:ReverseY_RBV' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:04:19 PM
INFO: More than one PVs with name '13ARV1:image1:ArraySize0_RBV' detected,
INFO: More than one PVs with name '13ARV1:image1:ArraySize1_RBV' detected,
INFO: More than one PVs with name '13ARV1:image1:ArraySize2_RBV' detected,
INFO: More than one PVs with name '13ARV1:image1:ColorMode_RBV' detected,
INFO: More than one PVs with name '13ARV1:image1:DataType_RBV' detected,
INFO: More than one PVs with name '13ARV1:image1:ArrayData' detected,
INFO: More than one PVs with name '13ARV1:image1:ArrayCounter_RBV' detected,
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:14:59 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:19:08 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:23:53 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:23:54 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:48:13 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:48:14 PM
additional response from: /169.254.0.2:5064 Sep 04, 2019 2:49:51 PM
Since, I am an EPICS user (not developer) and a beginner, I am unable to
comprehend this situation to view the Image Display. Please help of in
resolving this issue.
Please let me know if anything else needs to be done from my side.
Thanks and regards
Ashish Sharma
Engineer 'C'
Inter-University Accelerator Centre,
Aruna Asaf Ali Marg, New Delhi - 110067, India
Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
RE: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Mark Rivers via Tech-talk
Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Mark Rivers via Tech-talk
RE: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Engbretson, Mark S. via Tech-talk
Prev: RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
Next: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Engbretson, Mark S. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
