Subject: |
Re: Problems compiling base-3.15.6 with RTEMS |
Michael Westfall via Tech-talk <[email protected]> |
Cc: |
tech-talk <[email protected]> |
Date: |
Fri, 13 Sep 2019 11:58:20 -0300 |
Going back to a previous version of EPICS (R3.14.12.8) I see I have the same problem when compiling, but it's only a warning, not an error, which is probably why I hadn't noticed it before.
/gem_sw/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/mvme2307/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_PPCBUG -DNVRAM_INDIRECT -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: warning: bsp/bspExt.h: No such file or directory ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c: In function 'rtemsDevInit': ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:129: warning: implicit declaration of function 'bspExtInit' Yes, libbspExt is already installed.
EPICS R3.14.12.8 (and previous versions) find it without any problem. It's just EPICS R3.15.6 that can't find it for some reason.
acc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include -c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c
> ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: error: bsp/bspExt.h: No such file or directory
> make[3]: *** [devLibVMEOSD.o] Error 1
> make[3]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom/O.RTEMS-mvme3100'
> make[2]: *** [install.RTEMS-mvme3100] Error 2
> make[2]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src'
> make: *** [src.install] Error 2
> It can't find the header file for libbspExt in <bsp/bspExt.h>, even though it's right there where it's always been and can be found when compiling our previoous versions of EPICS...
> I've looked at all the files in .../base/configure, but I don't see what has changed that might cause this.
> Any pointers appreciated.
> Mike Westfall
> Control Systems Software Engineer
-- Mike Westfall
- Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
- Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
- Re: Problems compiling base-3.15.6 with RTEMS Heinz Junkes via Tech-talk
<2019>
<2019>
ANJ, 13 Sep 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
