1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: RE: Tech-talk Digest, Vol13, Issue381
To: 'peiyu Quan' <[email protected]>
Date: Fri, 13 Sep 2019 19:29:28 +0000
Ø  I am installing areadetector modules, It took about 20 mins, i didn't find any problem.
You can probably speed up the 20 minutes a lot by using “make –j” to do parallel make.
If the simDetector is still a problem please send the complete output when you run the following in the top-level ADSimDetector directory
make –sj clean
make
From: Tech-talk <[email protected]> On Behalf Of peiyu Quan via Tech-talk
Sent: Friday, September 13, 2019 11:51 AM
To: [email protected]
Subject: Tech-talk Digest, Vol13, Issue381
Dear
   I have installed most of modules in synApps before.
I am installing areadetector modules, It took about 20 mins, i didn't find any problem. But in finally,
It showed:
"/home/epics0/Apps/epics/base/configure/RULES_BUILD:191: recipe for target 'checkRelease' failed
make[5]: *** [checkRelease] Error 1
make[5]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
/home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[4]: *** [install.linux-x86_64] Error 2
make[4]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC/configure'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'configure.install' failed
make[3]: *** [configure.install] Error 2
make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'simDetectorNoIOC.install' failed
make[2]: *** [simDetectorNoIOC.install] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'iocs.install' failed
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector.install' failed
make: *** [/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector.install] Error 2
My first question is whether it can proved most of modules in areadetector have succeed in being installed, except simDetector?
My second question is how to solve this problem?
Thanks
Peiyu
UW-Madsion
Tech-talk Digest, Vol13, Issue381 peiyu Quan via Tech-talk
Prev: RE: Tech-talk Digest, Vol13, Issue381 Mark Rivers via Tech-talk
Next: RE: Tech-talk Digest, Vol13, Issue381 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Tech-talk Digest, Vol13, Issue381 peiyu Quan via Tech-talk
ANJ, 13 Sep 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
