1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tech-talk Digest, Vol13, Issue386
To: peiyu Quan <[email protected]>
Date: Mon, 16 Sep 2019 03:53:43 +0000
Hi Peiyu,
> ../md_linux.h:144:10: fatal error: usb.h: No such file or directory
>  #include "usb.h"
The missing file is provided by the operating system.  If you want to build the dxp module on Linux you need to install the package containing that file.
On Centos or RHEL the command is:
sudo yum install libusb-devel
That is clearly explained in my documentation for the dxp module:
https://cars9.uchicago.edu/software/epics/dxpDoc.html#Installing_Linux
From: Tech-talk <[email protected]> on behalf of peiyu Quan via Tech-talk <[email protected]>
Sent: Sunday, September 15, 2019 9:17 PM
To: [email protected]
Subject: Tech-talk Digest, Vol13, Issue386
Dear
I am installing dxp-R6-0
It showsome errors.
1.In file included from ../md_linux.c:65:0:
 #include "usb.h"
2.
nclude/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xia_usb_linux.c
../xia_usb_linux.c:41:10: fatal error: usb.h: No such file or directory
 #include <usb.h>
compilation terminated.
/home/epics0/Apps/epics/base/configure/RULES_BUILD:234: recipe for target 'xia_usb_linux.o' failed
make[3]: *** [xia_usb_linux.o] Error 1
make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64'
/home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'handelSrc.install' failed
make[1]: *** [handelSrc.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'dxpApp.install' failed
make: *** [dxpApp.install] Error 2
The process as following:
epics0@ubuntu:~/Apps/epics/synApps_6_1/support/dxp-R6-0$ make
make -C ./configure install
make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure/O.linux-x86_64'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure'
make -C ./dxpApp install
make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp'
make -C ./handelSrc install
make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF md_linux.d  ../md_linux.c
 #include "usb.h"
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xia_epp_linux.d  ../xia_epp_linux.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xia_usb_linux.d  ../xia_usb_linux.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xia_file.d  ../xia_file.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xia_assert.d  ../xia_assert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_xerxes.d  ../handel_xerxes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_system.d  ../handel_system.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_sort.d  ../handel_sort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_run_params.d  ../handel_run_params.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_run_control.d  ../handel_run_control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_log.d  ../handel_log.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_file.d  ../handel_file.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_dyn_module.d  ../handel_dyn_module.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_dyn_firmware.d  ../handel_dyn_firmware.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_dyn_detector.d  ../handel_dyn_detector.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_dyn_default.d  ../handel_dyn_default.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_detchan.d  ../handel_detchan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel_dbg.d  ../handel_dbg.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF psl.d  ../psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF fdd.d  ../fdd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF handel.d  ../handel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF md_log.d  ../md_log.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xerxes_io.d  ../xerxes_io.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF xerxes.d  ../xerxes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF stj_psl.d  ../stj_psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF stj.d  ../stj.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF udxp_psl.d  ../udxp_psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF udxp_common.d  ../udxp_common.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF udxp.d  ../udxp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF mercury_psl.d  ../mercury_psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF mercury.d  ../mercury.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF saturn_psl.d  ../saturn_psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include           -MM -MF saturn.d  ../saturn.c
 #include "usb.h"
Installing generic include file ../../../include/xia_common.h
mkdir ../../../include
Installing generic include file ../../../include/xia_xerxes.h
Installing generic include file ../../../include/xerxes_generic.h
Installing generic include file ../../../include/xia_xerxes_structures.h
Installing generic include file ../../../include/xerxes_structures.h
Installing generic include file ../../../include/xerxesdef.h
Installing generic include file ../../../include/handel.h
Installing generic include file ../../../include/handel_constants.h
Installing generic include file ../../../include/handeldef.h
Installing generic include file ../../../include/handel_generic.h
Installing generic include file ../../../include/md_generic.h
Installing generic include file ../../../include/handel_errors.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../saturn.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../saturn_psl.c
../saturn_psl.c: In function 'pslSetAcquisitionValues':
../saturn_psl.c:5618:32: warning: '%u' directive writing between 1 and 10 bytes into a region of size 6 [-Wformat-overflow=]
             sprintf(limit, "sca%u_lo", i);
../saturn_psl.c:5618:28: note: directive argument in the range [0, 2147483647]
In file included from /usr/include/stdio.h:862:0,
                 from ../saturn_psl.c:38:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: '__builtin___sprintf_chk' output between 8 and 17 bytes into a destination of size 9
   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
       __bos (__s), __fmt, __va_arg_pack ());
../saturn_psl.c:5634:32: warning: '%u' directive writing between 1 and 10 bytes into a region of size 6 [-Wformat-overflow=]
             sprintf(limit, "sca%u_hi", i);
../saturn_psl.c:5634:28: note: directive argument in the range [0, 2147483647]
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../mercury.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../mercury_psl.c
../mercury_psl.c: In function 'psl__GetSCAData':
../mercury_psl.c:6246:33: warning: '%lu' directive writing between 1 and 20 bytes into a region of size between 0 and 10 [-Wformat-overflow=]
     sprintf(memory, "burst:%#lx:%lu", addr, (unsigned long)totalSCA);
../mercury_psl.c:6246:21: note: using the range [0, 18446744073709551615] for directive argument
                 from ../xia_handel.h:43,
                 from ../mercury_psl.c:43:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: '__builtin___sprintf_chk' output between 10 and 39 bytes into a destination of size 18
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../udxp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../udxp_common.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../udxp_psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../stj.c
../stj.c: In function 'dxp_load_symbols_from_file':
../stj.c:740:57: warning: format '%d' expects argument of type 'int', but argument 3 has type 'long unsigned int' [-Wformat=]
                 sprintf(info_string, "Error allocating %d bytes for 'params->"
                                                        %ld
In file included from ../stj.c:43:0:
../stj.c: At top level:
../xia_stj.h:113:32: warning: 'dxp_find_file' declared 'static' but never defined [-Wunused-function]
 XERXES_STATIC FILE* XERXES_API dxp_find_file(const char *, const char *);
../xia_stj.h:115:30: warning: 'dxp_do_cmd' declared 'static' but never defined [-Wunused-function]
 XERXES_STATIC int XERXES_API dxp_do_cmd(int modChan, Board *board, byte_t cmd, unsigned int lenS,
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../stj_psl.c
../stj_psl.c:89:16: warning: 'psl__UpdateParams' declared 'static' but never defined [-Wunused-function]
 PSL_STATIC int psl__UpdateParams(int detChan, unsigned short type, int modChan,
../stj_psl.c: In function 'psl__SetBiasDacEnable':
../stj_psl.c:8228:34: warning: 'CHANENA' directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=]
     sprintf(BANKnDSPNAME, "BANK%dCHANENA", bank);
                 from ../stj_psl.c:45:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: '__builtin___sprintf_chk' output between 13 and 22 bytes into a destination of size 20
../stj_psl.c: In function 'psl__SetTThresh':
../stj_psl.c:2004:34: warning: 'ADCGAIN' directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=]
     sprintf(BANKnDSPNAME, "BANK%dADCGAIN", bank);
../stj_psl.c: In function 'psl__SetEThresh':
../stj_psl.c:2104:34: warning: 'ADCGAIN' directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=]
../stj_psl.c: In function 'psl__UpdateGain':
../stj_psl.c:2365:34: warning: 'ADCGAIN' directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=]
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xerxes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xerxes_io.c
../xerxes_io.c:57:13: warning: 'INFO_STRING' defined but not used [-Wunused-variable]
 static char INFO_STRING[INFO_LEN];
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../md_log.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../fdd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../psl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_dbg.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_detchan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_dyn_default.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_dyn_detector.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_dyn_firmware.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_dyn_module.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_file.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_log.c
In file included from ../handel_log.c:42:0:
../handel_log.h:55:13: warning: 'info_string' defined but not used [-Wunused-variable]
 static char info_string[400];
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_run_control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_run_params.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_sort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_system.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../handel_xerxes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xia_assert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xia_file.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include      -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include  -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include   -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include   -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include   -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include  -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include  -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include   -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include        -c ../xia_usb_linux.c
../xia_usb_linux.c:41:10: fatal error: usb.h: No such file or directory
 #include <usb.h>
compilation terminated.
/home/epics0/Apps/epics/base/configure/RULES_BUILD:234: recipe for target 'xia_usb_linux.o' failed
make[3]: *** [xia_usb_linux.o] Error 1
make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64'
/home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'handelSrc.install' failed
make[1]: *** [handelSrc.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'dxpApp.install' failed
make: *** [dxpApp.install] Error 2
Thanks
Peiyu
Tech-talk Digest, Vol13, Issue386 peiyu Quan via Tech-talk
Prev: Tech-talk Digest, Vol13, Issue386 peiyu Quan via Tech-talk
Next: How to handle various response format from device in streamdevice protocol? Chiang, Liang-Chih [江良志] via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
