1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AW: Correct Settings for PIE816 Controller
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Sintschuk, Michael" <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Sep 2019 15:25:27 +0000
The build succeeded; the messages you are seeing are warnings, which you
can ignore.
Kevin
On 9/18/19 9:44 AM, Sintschuk, Michael via Tech-talk wrote:
> Thanks Torsten, this helped with the ATHM field which is 0 now. So the
> MSTA bits are now 2338 that corresponds to this status.
> After commenting out the line "status.Bits.RA_HOME =
> status.Bits.RA_DONE;" in "drvPIE816.cc" i recompiled the motor-module
> and encountered this problem:
> make[3]: Entering directory
> '/soft/epics/modules/motor-R6-10-1/motorApp/PiSrc/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_
> -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC
> -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc
> -I../../../include/os/Linux -I../../../include
> -I/usr/local/epics/base/../modules/asyn/include
> -I/usr/local/epics/base/include/compiler/gcc
> -I/usr/local/epics/base/include/os/Linux
> -I/usr/local/epics/base/include        -MM -MF drvPIE816.d ../drvPIE816.cc
> -I/usr/local/epics/base/include        -c ../drvPIE816.cc
> ../drvPIE816.cc:94:39: warning: ISO C++ forbids converting a string
> constant to ‘char*’ [-Wwrite-strings]
>                                  "K","L"};
> ../drvPIE816.cc: In function ‘int set_status(int, int)’:
> ../drvPIE816.cc:233:25: warning: variable ‘mr’ set but not used
> [-Wunused-but-set-variable]
>       struct motorRecord *mr;
> ../drvPIE816.cc:237:66: warning: unused variable ‘online_status’
> [-Wunused-variable]
>       unsigned int overflow_status, ontarget_status, servo_status,
> online_status;
> ../drvPIE816.cc: In function ‘int motor_init()’:
> ../drvPIE816.cc:584:10: warning: unused variable ‘retry’ [-Wunused-variable]
>        int retry = 0;
> /usr/bin/ar -rc    libPI.a         devPIC844.o drvPIC844.o PiRegister.o
> devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o
> PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o
> drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o
> devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o
> PIE516Register.o devPIE517.o drvPIE517.o PIE517Register.o devPIE816.o
> drvPIE816.o PIE816Register.o
> /usr/bin/ranlib libPI.a
> /usr/bin/g++ -o libPI.so -shared -fPIC -Wl,-hlibPI.so
> -L/soft/epics/modules/motor-R6-10-1/lib/linux-x86_64
> -L/soft/epics/modules/asyn4-32/lib/linux-x86_64
> -L/soft/epics/base-3.15.5/lib/linux-x86_64
> -Wl,-rpath,/soft/epics/modules/motor-R6-10-1/lib/linux-x86_64
> -Wl,-rpath,/soft/epics/modules/asyn4-32/lib/linux-x86_64
> -Wl,-rpath,/soft/epics/base-3.15.5/lib/linux-x86_64           -rdynamic
> -m64             devPIC844.o drvPIC844.o PiRegister.o devPIC630.o
> drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o
> devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o
> PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o
> drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o
> devPIE517.o drvPIE517.o PIE517Register.o devPIE816.o drvPIE816.o
> PIE816Register.o   -lmotor -lasyn -ldbRecStd -ldbCore -lca -lCom
> -lpthread   -lreadline -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/linux-x86_64/libPI.so
> Installing library ../../../lib/linux-x86_64/libPI.a
> make[3]: Leaving directory
> I think this has nothing to do with removing of the upper line because
> it is located in line 313.
> My C / C++ knowledge is poor, so i don't know if my drvPIE816.cc is
> corrupted... I always compile the whole motor-package and this is the
> only file causing errors.
> Maybe its because of my Linux-System, some missing package? Can someone
> tell?
Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Prev: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Next: Re: AW: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
