1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AW: Correct Settings for PIE816 Controller
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, "Sintschuk, Michael" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Sep 2019 16:38:30 +0000
I will make time to manually apply those changes to the many driver
repos I created, since I failed to merge the pull request before the
motor repo split.
Kevin
On 9/18/19 11:19 AM, Torsten Bögershausen via Tech-talk wrote:
> Hej all,
> The warning(s) are actually fixed here:
> <https://github.com/epics-modules/motor/pull/128/commits/13a8649abbb80c884d55169aa99647c76bb4b04d>
> So I hope that someone finds time to merge/apply
> those fixes into the code base.
AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Prev: Re: AW: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Next: Control System Studio (CSS) and PV Adrian martinez munera via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
ANJ, 19 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
