1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: areadetector NDArrayPool issues
To: tech-talk <[email protected]>
Date: Mon, 23 Sep 2019 12:49:28 +0000
Forwarding to tech-talk, issue resolved.
From: Sandeep Kumar Malu - UKRI STFC <[email protected]>
Sent: Monday, September 23, 2019 3:04 AM
To: Mark Rivers
Subject: RE: areadetector NDArrayPool issues
Hi Mark
Thank you for pointing this out. Indeed, no more error messages and camera is running for a long time without crashing.
Many Thanks
Sandeep Malu
-----Original Message-----
Sent: 20 September 2019 13:15
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Subject: Re: areadetector NDArrayPool issues
Hi Sandeep,
The stack trace indicates the problem is in NDPluginStats following a call to its writeInt32 method.  That looks like it could be an issue that was fixed in ADCore R3-6.  This is from the R3-6 release notes:
NDPluginStats
  *   Removed calls to processCallbacks() when CursorX, CursorY, or CentroidThreshold are changed. This is no longer thread safe. To see updates when plugin is not receiving NDArrays change the PV and then press ProcessPlugin.
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
Sent: Friday, September 20, 2019 5:28 AM
To: [email protected]
Subject: areadetector NDArrayPool issues
I am running multiple prosilica cameras. Some camera crashes in 5 min while others run for 5-6 hrs. My guess is something to do with memory stuffs (alloc, dealloc, buffer size, stack size etc).  I am also using adPython plugin to do image processing using openCV. The error I get is -
NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f1a640010e0
Thread scan-1 (0x562a979bd2c0) can't proceed, suspending.
Dumping a stack trace of thread 'scan-1':
[    0x7fad8bb6db13]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(epicsStackTrace+0x73)
[    0x7fad8bb5d4e5]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(cantProceed+0xc5)
[    0x7fad8b136b6f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libADBase.so(_ZN11NDArrayPool7reserveEP7NDArray+0xdf)
[    0x7fad8b37f30f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x36f)
[    0x7fad8b3c315d]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats16processCallbacksEP7NDArray+0x3d)
[    0x7fad8b3c4164]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats10writeInt32EP8asynUseri+0xe4)
[    0x7fad8a844eab]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(writeInt32+0x3b)
[    0x7fad8a856085]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processCallbackOutput+0x25)
[    0x7fad8a823995]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(queueRequest+0x285)
[    0x7fad8a8566d9]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processLo+0x59)
[    0x7fad8c03fd38]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0xd8)
[    0x7fad8bdba34f]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbProcess+0x23f)
[    0x7fad8bdc8efb]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbPutLink+0x12b)
[    0x7fad8c0379d8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(execOutput+0x88)
[    0x7fad8c0380bf]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x5ef)
[    0x7fad8bdd5bb0]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(recGblFwdLink+0x10)
[    0x7fad8c037db8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x2e8)
[    0x7fad8bdcac14]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(scanList+0x64)
[    0x7fad8bdcafd8]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(periodicTask+0x1a8)
[    0x7fad8bb67dc8]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(start_routine+0xf8)
[    0x7fad894086db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[    0x7fad89d4988f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread scan-1 (0x55f358edc150) suspended
The version of EPICS and support modules are
a)       base - 3.15.6
b)      asyn - 4-33
c)       calc - 3-6-1
d)      seq - 2.1.21
e)      streamDevice - 2-6
f)        busy - 1-6
g)       areadetector - 3-5
1.       ADcore - 3-5
2.       ADsupport - 1-9
3.       ADprosilica - 2-5
h)      Adpython - 1-4 (https://epics.anl.gov/tech-talk/2019/msg00588.php)
The st.cmd file looks like
#   Prosilica driver
prosilicaConfig("$(PREFIX)CAM", $(CAMID), 50, 0)
dbLoadRecords("$(ADPROSILICA)/db/prosilica.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("ADBase.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
# Create ROI plugins
NDROIConfigure("$(PREFIX)ROI", $(QSIZE), 0, "$(PREFIX)CAM", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDROI.template", "P=$(PREFIX),R=ROI1:,  PORT=$(PREFIX)ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)CAM")
# Create a transform plugin
NDTransformConfigure("$(PREFIX)TRANS", $(QSIZE), 0, "$(PREFIX)ROI", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDTransform.template", "P=$(PREFIX),R=Trans1:,  PORT=$(PREFIX)TRANS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)ROI")
# adPython plugin for centroid
adPythonPluginConfigure("$(PREFIX)CENTROID", "$(TOP)/pythonScripts/adPythonCentroid.py", "Template", 10, 0, "$(PREFIX)TRANS", 0, 100, 50,1,200097152)
dbLoadRecords("NDPluginBase.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS,NDARRAY_ADDR=0")
dbLoadRecords("$(ADPYTHON)/db/adPythonPlugin.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID, TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS")
# standard arrays plugin
NDStdArraysConfigure("$(PREFIX)Image", 3, 0, "$(PREFIX)TRANS", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template","P=$(PREFIX),R=image1:,PORT=$(PREFIX)Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)OVER,TYPE=Int8,FTVL=UCHAR,NELEMENTS=1245488)")
Any way to fix this?
Many Thanks
Sandeep Malu
areadetector NDArrayPool issues Sandeep Kumar Malu - UKRI STFC via Tech-talk
Prev: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
Next: Re: Base R7.0.2.2 VME_IO Parsing Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Next: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
