1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Compile problems with R3.15.6
From: Michael Westfall via Tech-talk <[email protected]>
To: "[email protected] Talk" <[email protected]>
Date: Tue, 24 Sep 2019 11:40:54 -0300
I have installed EPICS R3.15.6 here and now when I compile a support module, it fails with this:
Installing created db file ../../../db/bctest.db
/gem_sw/epics/R3.15.6/base/configure/RULES.Db:521: Building ../../../db/bctest.db (from ../O.Common/bctest.db) (../O.Common/bctest.db newer)
+ perl -CSD /gem_sw/epics/R3.15.6/base/bin/linux-x86_64/installEpics.pl -d -m 444 ../O.Common/bctest.db ../../../db
mkdir ../../../db
make[3]: *** No rule to make target `bctest.db.d', needed by `build'.  Stop.
make[3]: Leaving directory `/home/mwestfall/bancomm/bancommApp/Db/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/home/mwestfall/bancomm/bancommApp/Db'
make[1]: *** [Db.install] Error 2
make[1]: Leaving directory `/home/mwestfall/bancomm/bancommApp'
make: *** [bancommApp.install] Error 2
[mwestfall@sbfrtdev-lv3 bancomm]$
I imagine this might have something to do with our custom rules that we add in here at Gemini, but I'm not seeing how.
Any pointers as to where I should be looking to figure out why the bctest.db.d file is not being created?
Thanks...
Mike Westfall
Control Systems Software Engineer
Re: Compile problems with R3.15.6 Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] Re: SRS DS335 and DS345 device support Geng, Xiaosong via Tech-talk
Next: Re: Compile problems with R3.15.6 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
