1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Lua global variables
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, James King - UKRI STFC <[email protected]>
Date: Wed, 16 Oct 2019 18:29:11 +0000
>we cannot use local variables as they drop out of scope due to the nature of Lua interactive mode scopes.
Yeah, due to the way the input is analyzed to see if you have a valid code chunk and the need for the code to be turned into opcodes for the interpreter, scopes end up being a bit weird with a shell. If you have a multiline statement (ie functions or conditionals), local variables can be used and the definition will be confined to that scope. For single-line commands, the scope is the line itself and local variables will disappear by the next line, unfortunately.
>Or any information as to how global variables are contained in the Lua shell?
Global variables stay in scope until the lua shell is exited, they won't be exported into the overarching environment variables unless you use epicsEnvSet. Calling another lua shell within the current one (like using the '<' character to include another file) only has the effect of changing where input is coming from, so global variables will be shared between the two and the end of the inner context won't cause global variables to expire. One thing to note, though, if you are fully replacing the ioc shell with the lua shell in your <app>Main.c, there are two calls to the lua shell. One is for if you specify a startup script on the command line, and then another to provide the interactive shell. Since they are two different calls, if you specify global variables in your st.lua or whatever file, they won't be there once you reach the interactive shell.
From: Tech-talk <[email protected]> on behalf of James King - UKRI STFC via Tech-talk <[email protected]>
Sent: Wednesday, October 16, 2019 11:34 AM
To: [email protected] <[email protected]>
Subject: EPICS Lua global variables
Hello Tech-talk,
I have been working on getting an IOC booting with Lua. Lua guidelines suggest the use of local variables rather than global. I notice that Macros are available as global variables and we cannot use local variables as they drop out of scope due to the nature of Lua interactive mode scopes.
Does anyone have any experience of using local variables in Lua IOC boot scripts? Or any information as to how global variables are contained in the Lua shell?
Many thanks for any replies and help given.
Kind regards,
James
EPICS Lua global variables James King - UKRI STFC via Tech-talk
Prev: EPICS Lua global variables James King - UKRI STFC via Tech-talk
Next: Re: few questions on autosave Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: EPICS V7 and the return of dbReadTest and dbreport Luchini, Kristi L. via Tech-talk
ANJ, 18 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
