1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why should I care about breakpoint table monotonicity?
From: Ernesto Paiser via Tech-talk <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Wed, 30 Oct 2019 18:08:17 -0700
Hi Andrew,
I'm getting the same problem as Emmanuel:
Unknown option:b
I'm using EPICS 3.15.5:
I added in my Makefile:
DBEXPAND += -b
records_DBD += recordsBpt.dbd
Is this option still working in 3.15.5?
Thanks
 Ernesto
Here the output:
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/home/clsfs/epics/2/git/epics-iocs/cls1/drv/records/src/O.linux-x86_64'
Creating dbd file records.dbd
perl -CSD /opt/epics/base/bin/linux-x86_64/dbdExpand.pl -b -I /home/local/epics/iochost/clsbpm1/dbd -I /opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd -I /opt/epics/extensions/synApps_6_1/support/StreamDevice-2-8-9/dbd -I /opt/epics/extensions/synApps_6_1/support/calc-R3-7-3/dbd -I /opt/epics/extensions/src/csm-4.5/dbd -I /opt/epics/extensions/synApps_6_1/support/autosave-R5-10/dbd -I. -I.. -I../O.Common -I../../../dbd -I/opt/epics/base/dbd -o records.dbd base.dbd asSupport.dbd recordsSupport.dbd /opt/epics/extensions/synApps_6_1/support/calc-R3-7-3/dbd/calcSupport.dbd /opt/epics/extensions/synApps_6_1/support/StreamDevice-2-8-9/dbd/stream.dbd /opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/asyn.dbd /opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/drvAsynIPPort.dbd /opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/drvAsynSerialPort.dbd /opt/epics/extensions/src/csm-4.5/dbd/cvtRecord.dbd recordsBpt.dbd
Unknown option: b
Usage: dbdExpand [-D] [-I dir] [-S macro=val] [-o out.dbd] in.dbd ... at /opt/epics/base/bin/linux-x86_64/dbdExpand.pl line 20.
make[1]: *** [../O.Common/records.dbd] Error 255
make[1]: Leaving directory `/home/clsfs/epics/2/git/epics-iocs/cls1/drv/records/src/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
Ernesto Paiser
Senior Controls Software Engineer
Lyncean Technologies, Inc.
47633 Westinghouse Drive
Fremont, CA 94539
Phone: +1-650-320-8300 ext. 452
www.lynceantech.com
Re: Why should I care about breakpoint table monotonicity? Andrew Johnson via Tech-talk
Prev: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
Next: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
Next: Re: Why should I care about breakpoint table monotonicity? Andrew Johnson via Tech-talk
ANJ, 05 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
