1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No TCP server started
From: Pierrick M Hanlet via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 Oct 2019 21:26:22 +0000
Here's what I get from a stripped down epicsEnvShow.
EPICS_PATH=/home/epics/epicsDEV
EPICS_IOCTOPS=/home/epics/epicsDEV/iocTops
EPICS_PVA_ADDR_LIST=131.225....
EPICS_BASE=/home/epics/epicsDEV/base
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_EXTENSIONS=/home/epics/epicsDEV/Extensions
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=linux-x86_64
EPICS_CONFIG=/home/epics/epicsDEV/Config
EPICS_CA_ADDR_LIST=131.225....
EPICS_SOFTWARE=/home/epics/epicsDEV/Software
EPICS_CA_MAX_ARRAY_BYTES=131072
EPICS_SUPPORT=/home/epics/epicsDEV/Support
EPICS_VERSION_MAJOR=7
EPICS_VERSION_MIDDLE=0
EPICS_VERSION_MINOR=3
EPICS_VERSION_PATCH=0
EPICS_VERSION_SNAPSHOT=
EPICS_VERSION_SITE=
EPICS_VERSION_SHORT=7.0.3
EPICS_VERSION_FULL=7.0.3
EPICS_IOC_OWNER=hanlet
EPICS_IOC_GROUP=FE_group
EPICS_IOC_LOCATION=???
On 10/31/19 9:19 AM, Michael Davidsaver wrote:
> "CAS: No TCP server started" means that the CA server configuration, when applied
> to the host system, has resulted in no TCP server sockets being created.  So the
> CA server would be inoperative.  The lack of previous errors is strange.
> I'd expect to see eg. some "bind error"s shown.
> What $EPICS_* environment variables are set?
> On 10/29/19 10:25 AM, Pierrick M Hanlet via Tech-talk wrote:
>> Hi,
>> I've several soft IOCs happily running 7.0.3 on linux-x86_64 on different ports.  However,
>> I have a new one which is connected to a ethernet<->serial converter which runs
>> without issue from a terminal, but fails with "No TCP server started" when started
>> from procServ.  A similar message was reported to core-talk by Heinz Junkes when
>> using 3.16.0.1-DEV-fhi.
>> This has nothing to do with my databases, as I have them commented out:
>> My startup command is:
>> epics:~/epicsDEV/Config/ProcLauncher> procServ -i ^D^C --killsig 15 --logfile /home/epics/epicsDEV/ioc_logs/Keithley2700_2019_10_29__11_59_38.log --name Keithley2700 --pidfile /home/epics/.PROCSERV_CMD_1572368378214534208 --quiet 7718 /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd
>> And the resulting log file has:
>> @@@ Restarting child "Keithley2700"
>> @@@    (as /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd)
>> @@@ The PID of new child "Keithley2700" is: 7855
>> #!../../bin/linux-x86_64/Keithley2700
>> ## You may have to change Keithley2700 to something else
>> ## everywhere it appears in this file
>> < envPaths
>> epicsEnvSet("IOC","iocKeithley2700")
>> epicsEnvSet("TOP","/home/epics/epicsDEV/iocTops/Multimeter")
>> epicsEnvSet("EPICS_BASE","/home/epics/epicsDEV/base")
>> epicsEnvSet("EPICS_SUPPORT","/home/epics/epicsDEV/Support")
>> epicsEnvSet("ASYN","/home/epics/epicsDEV/Support/asyn")
>> epicsEnvSet("CALC","/home/epics/epicsDEV/Support/calc")
>> epicsEnvSet("STREAM","/home/epics/epicsDEV/Support/StreamDevice")
>> epicsEnvSet("ALIVE","/home/epics/epicsDEV/Support/alive")
>> epicsEnvSet("KEITHLEY","/home/epics/epicsDEV/Support/Keithley")
>> epicsEnvSet("EPICS_IOC_OWNER","hanlet")
>> epicsEnvSet("EPICS_IOC_GROUP","FE_group")
>> epicsEnvSet("EPICS_IOC_LOCATION","???")
>> cd "/home/epics/epicsDEV/iocTops/Multimeter"
>> ## Register all support components
>> dbLoadDatabase "dbd/Keithley2700.dbd"
>> Keithley2700_registerRecordDeviceDriver pdbbase
>> ## Configure IP port
>> drvAsynIPPortConfigure("keithley","131.225.138.251:10002",0,0,0)
>> ## Debuggin
>> asynSetTraceIOMask("keithley",0,2)
>> asynSetTraceMask("keithley",0,9)
>> ## Load record instances
>> #dbLoadRecords("db/Keithley2700.db")
>> #dbLoadRecords("db/alive.db")
>> #dbLoadRecords("db/watcher.db")
>> ## Protocol file
>> epicsEnvSet("STREAM_PROTOCOL_PATH","/home/epics/epicsDEV/Support/Keithley/Keithley2700App/protocol")
>> ## Start IOC
>> cd "/home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700"
>> iocInit
>> Starting iocInit
>> ## EPICS R7.0.3
>> ## EPICS Base built Oct 23 2019
>> Thread _main_ (0x1b50450) can't proceed, suspending.
>> Dumping a stack trace of thread '_main_':
>> [    0x7fc82a4fe25b]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(epicsStackTrace+0x4b)
>> [    0x7fc82a4ee818]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(cantProceed+0xb8)
>> [    0x7fc82a9f4be9]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(rsrv_init+0xf69)
>> [    0x7fc82a9e07ab]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(dbInitServers+0x1b)
>> [    0x7fc82a9f19de]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocBuild+0x2e)
>> [    0x7fc82a9f1b89]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocInit+0x9)
>> [    0x7fc82a4e9555]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(iocshBody+0xb15)
>> [          0x407bb2]: ../../bin/linux-x86_64/Keithley2700(main+0x12)
>> [    0x7fc828d64545]: /lib64/libc.so.6(__libc_start_main+0xf5)
>> [          0x407bfd]: ../../bin/linux-x86_64/Keithley2700(_start+0x29)
>> Any ideas?  If helpful, the device is a Lantronix UDS2100 serial-to-ethernet converter; though I
>> don't know if that matters.
>> Thanks,
>> Pierrick
>> Pierrick Hanlet
>> Fermi National Accelerator
>> Accelerator Front End Controls
>> +1-630-840-5555 -- lab
>> +1-312-687-4980 -- mobile
>> "Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
Re: No TCP server started Mark Rivers via Tech-talk
No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Michael Davidsaver via Tech-talk
Prev: Re: No TCP server started Michael Davidsaver via Tech-talk
Next: Re: No TCP server started Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
