Subject: |
build stream |
=?gb18030?b?t+fQ0Muu?= via Tech-talk <[email protected]> |
To: |
"=?gb18030?b?dGVjaC10YWxr?=" <[email protected]> |
Date: |
Sun, 3 Nov 2019 23:16:44 +0800 |
Hi all, I met some simple question when I using stream and asyn. I want to add the stream in my example, created by makeBaseApp.pl.
I have added the two lines in application Makefile. PROD_LIBS += stream PROD_LIBS += asyn
but failed when add these:
include "base.dbd" include "stream.dbd" include "asyn.dbd"
It said these when I add them in src of src/exampleApp.
" dbdExpand.pl: Can't find file 'stream.dbd' while reading 'stream.dbd' to create 'example1.dbd' Your Makefile may need this dependency rule: $(COMMON_DIR)/example1.dbd: $(COMMON_DIR)/stream.dbd dbdExpand.pl: Can't find file 'asyn.dbd' " What should I do.
Thanks, Feng W
RE: No TCP server started Mark Rivers via Tech-talk
Re: No TCP server started Ralph Lange via Tech-talk
<2019>
2025
Re: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released Williams Jr., Ernest L. via Tech-talk
execute python from st.cmd Sandeep Kumar Malu - UKRI STFC via Tech-talk
<2019>
2025
ANJ, 04 Nov 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
