1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Trying to get new R3.15.7 and synapps 6.1 working.
To: "Lang, Keenan C." <[email protected]>
Cc: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 4 Nov 2019 15:52:08 -0800
Thanks for the information.  I’ve followed your latter suggestion and things are now running.
Perhaps I should push an update to the Caen FastPS support module with this change.
Again, thanks!
On Nov 4, 2019, at 3:38 PM, Lang, Keenan C. <[email protected]> wrote:
Looking over makefiles, if the CALC module is defined in the StreamDevice RELEASE file, the stream.dbd file will contain that scalcout device support line. The CaenFastPS module then includes stream.dbd without also including sCalcoutRecord.dbd (or calcSupport.dbd which grabs all the calc dbd files) which means that the scalcout record is never defined when the dbd is expanded.
You'll either need to:
  * comment out the CALC module in StreamDevice,
  * include the calc module and the needed dbd files into the CaenFastPS module,
  * or change the inclusion of stream.dbd to including the file stream-base.dbd instead
Eric Norum
[email protected]
Trying to get new R3.15.7 and synapps 6.1 working. Eric Norum via Tech-talk
Re: Trying to get new R3.15.7 and synapps 6.1 working. Lang, Keenan C. via Tech-talk
Prev: Re: Trying to get new R3.15.7 and synapps 6.1 working. Lang, Keenan C. via Tech-talk
Next: RE: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Two v7.0.3.1 questions Pierrick M Hanlet via Tech-talk
ANJ, 05 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
