1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Two v7.0.3.1 questions
To: 'Pierrick M Hanlet' <[email protected]>
Date: Tue, 5 Nov 2019 18:20:15 +0000
Hi Pierrick,
I have used epicsRegisterFunction from C++ code with no problems on 7.0.3.1.  Look at:
https://github.com/areaDetector/ADCore/blob/master/ADApp/ADSrc/myAttributeFunctions.cpp
It contains:
static int myAttrFunct1(const char *paramString, void **functionPvt, functAttribute *pAttribute) {
extern "C" {
epicsRegisterFunction(myAttrFunct1);
Ø  /home/epics/epicsDEV/base/include/epicsTypes.h:44:14: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
Ø  typedef long long       epicsInt64;
This suggests that your compiler is being set to use ISO 1998 mode.  Depending on the version of gcc you can set it to another standard by setting USR_CFLAGS += -std=[desired version].  Do the same for USR_CXXFLAGS for C++ code.
Look at man gcc to see the available options.
From: Tech-talk <[email protected]> On Behalf Of Pierrick M Hanlet via Tech-talk
Sent: Tuesday, November 5, 2019 10:22 AM
To: [email protected]
Subject: Two v7.0.3.1 questions
I'm on a linux SL7.6 machine and am using v7.0.3.1.
I don't understand the epicsRegisterFunction macro.  I've used aSubRecords dozens of times
with C files, but now that I'm attempting to use it in a C++ file, I cannot get the macro to
do its magic.  At the bottom of my xxx.cpp file with all the correct headers, I have the code:
extern "C" {
  short PVdata(struct aSubRecord*);
short PVdata(struct aSubRecord *pvData) {
  return 0;               // this will eventually be real code
extern "C" {
  epicsRegisterFunction(PVdata);
This results in:
/home/epics/epicsDEV/base/include/epicsExport.h:37:22: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object [-Wpedantic]
 epicsExportRegistrar(register_func_ ## func)
/home/epics/epicsDEV/base/include/epicsExport.h:32:72: note: in definition of macro 'epicsExportRegistrar'
 epicsShareFunc REGISTRAR EPICS_EXPORT_PFUNC(func) = (REGISTRAR)(void*)&func
../acnetPV.cpp:167:3: note: in expansion of macro 'epicsRegisterFunction'
Am I misusing epicsRegisterFunction() somehow?
As a second issue, I get some weird warning messages:
In file included from /home/epics/epicsDEV/base/include/epicsStdlib.h:20:0,
                 from acnetPV_registerRecordDeviceDriver.cpp:9:
/home/epics/epicsDEV/base/include/epicsTypes.h:45:23: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
 typedef unsigned long long epicsUInt64;
In file included from acnetPV_registerRecordDeviceDriver.cpp:9:0:
/home/epics/epicsDEV/base/include/epicsStdlib.h:39:43: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
     epicsParseLLong(const char *str, long long *to, int base, char **units);
/home/epics/epicsDEV/base/include/epicsStdlib.h:41:53: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
     epicsParseULLong(const char *str, unsigned long long *to, int base, char **units);
In file included from /home/epics/epicsDEV/base/include/registryCommon.h:15:0,
                 from acnetPV_registerRecordDeviceDriver.cpp:12:
/home/epics/epicsDEV/base/include/dbJLink.h:69:48: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
     jlif_result (*parse_integer)(jlink *, long long num);
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: Two v7.0.3.1 questions Pierrick M Hanlet via Tech-talk
Prev: RE: StreamDevice - disable INVALID/CALC alarm for @mismatch O'Hea, James (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Two v7.0.3.1 questions Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Two v7.0.3.1 questions Pierrick M Hanlet via Tech-talk
ANJ, 05 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
