1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record not sending monitor on .NORD field
From: Lucas Russo via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 6 Nov 2019 09:48:55 -0300
Hi again,
As a workaround to the problem I FLNK'ed the "waveform" record to an "ai" record that fetches its .NORD value. The "ai" send the monitors correctly and I can monitor them from the other IOC.
Cheers!
Lucas
On Thu, Oct 31, 2019 at 7:51 AM Lucas Russo <[email protected]> wrote:
Hello everyone,
I've been trying to use the .NORD field value to trigger a change in a subArray record. I'm doing it like this: https://github.com/lnls-dig/tune-epics-ioc/blob/master/tuneApp/Db/tune.db#L519
I can see that the Trace-Mon record is correctly sending monitors on the .VAL field. Also, the value of .NORD changes correctly as well, but it's just not sending any monitors (tested with camonitor).
I'm using epics base 3.15.5. From the release notes it seems this has been fixed in 3.15.0.1.
Am I missing something here?
Thanks a lot!
Lucas
Re: Waveform record not sending monitor on .NORD field Michael Davidsaver via Tech-talk
Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
Prev: Modbus Problems 黄佳伟 via Tech-talk
Next: init a waveform Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
Next: Re: Waveform record not sending monitor on .NORD field Michael Davidsaver via Tech-talk
ANJ, 06 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
