1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: I can't figure out how to change the rate guarantee...
From: Bruno Martins via Tech-talk <[email protected]>
To: Aaron Brown <[email protected]>
Date: Thu, 7 Nov 2019 13:42:50 -0500
If you set the MDEL field to "-1" you will get an update every time the PV processes, regardless if the value changed or not.
Bruno
On Thu, Nov 7, 2019 at 1:00 PM Aaron Brown via Tech-talk <[email protected]> wrote:
Hello,
I am using a Channel Access client to monitor a list of PVs.
A few of them are temperature values that don't change frequently.
However, I would like to receive a value from these PVs even if the value hasn't changed to ensure the sensor is still operational.
Is there a way to do this?
I read something about a "rate guarantee", but have seen no information about how to change it.
Any help will be greatly appreciated.
Aaron Brown
Detector Support Group
Jefferson Lab
Re: [EXTERNAL] Re: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
Prev: RE: Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Next: Re: [EXTERNAL] Re: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
ANJ, 07 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
