1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Connection Timeout Using Asyn and StreamDevice with Ethernet Device
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: Kyle Hesse <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Thu, 7 Nov 2019 21:27:47 +0000
I would suggest asking the manufacturer of the power meter how the meter
behaves when a client disconnects suddenly.
I've seen a problem like this in the past with a piezo controller that
would only connect to an EPICS IOC once for each power-cycle.  The
solution was a firmware upgrade that sent TCP keepalive packets and
terminated the connection after a TCP keepalive timeout.
Kevin
On 11/7/19 2:39 PM, Kyle Hesse via Tech-talk wrote:
> Yes, a restart of the IOC does not reconnect. I have to cycle power.
> AutoConnect does try its best though.
Connection Timeout Using Asyn and StreamDevice with Ethernet Device Kyle Hesse via Tech-talk
RE: Connection Timeout Using Asyn and StreamDevice with Ethernet Device Mark Rivers via Tech-talk
Re: Connection Timeout Using Asyn and StreamDevice with Ethernet Device Kyle Hesse via Tech-talk
Prev: RE: Connection Timeout Using Asyn and StreamDevice with Ethernet Device Mark Rivers via Tech-talk
Next: RE: Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
ANJ, 07 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
