1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Monitored PV limit?
From: Aaron Brown via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 8 Nov 2019 18:22:29 +0000
Hi Ralph,
That was exactly the limit I was experiencing. Changing that limit fixed the problem.
Ultimately I would create a different client to monitor a large number of PVs (I am currently working on creating a large scale data logger), but for now I just wanted to get a better understanding of how the client works and  make sure that the client I set up worked the way I wanted it to.
Thanks for the quick answer!
Aaron Brown
Detector Support Group
Jefferson Lab
Sent: Friday, November 8, 2019 11:22 AM
To: EPICS Tech Talk <[email protected]>
Cc: Aaron Brown <[email protected]>
Subject: [EXTERNAL] Re: Monitored PV limit?
Hi Aaron,
Assuming you refer to the caMonitor example code that comes with Base: this is an example for how to use the CA client library. In its sources it sets (line 27)
#define MAX_PV 1000
which is most probably the limit you are experiencing.
For monitoring 5000 values, a command line client does not sound like a reasonable tool. If you can give some more details on your use case, there might be better ways to get it done.
Cheers,
~Ralph
On Fri, 8 Nov 2019 at 17:09, Aaron Brown via Tech-talk <[email protected]> wrote:
Hello All,
I have a list of roughly 5000 PVs that I would like to monitor, but when I run the "./caMonitor" program with the full list it seems to only monitor less than half of the list.
Is there a limit to the number of PVs that can be monitored using the example "./caMonitor" program?
Thanks for any help that can be offered,
Aaron Brown
Jefferson Lab
Re: [EXTERNAL] Re: Monitored PV limit? Michael Davidsaver via Tech-talk
Monitored PV limit? Aaron Brown via Tech-talk
Re: Monitored PV limit? Ralph Lange via Tech-talk
Prev: RE: ADAndor iKon CCD low saturation point Heesterman, Peter J via Tech-talk
Next: Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monitored PV limit? Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Re: Monitored PV limit? Michael Davidsaver via Tech-talk
ANJ, 08 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
