1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: RE: Xilinx ARM64 mmap and regdev module compile error
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: Jeong Han Lee <[email protected]>, "[email protected]" <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 8 Nov 2019 23:38:10 +0000
Hi Jeong Han,
Sounds good.
The memDisplay module added and solved compile errors.
One more error is coming from the "regdev/test" file.
fpga@debian10-zcu102:~/iocApp/regdev/test$ make
gcc -g -c test_regDevWriteNumber.c -Wall -Werror \
-I. -I .. -I/home/fpga/epics/base-3.16.2/include -I/home/fpga/epics/base-3.16.2/include/os/Linux
In file included from /home/fpga/epics/base-3.16.2/include/epicsTypes.h:19,
                 from test_regDevWriteNumber.c:4:
/home/fpga/epics/base-3.16.2/include/compilerDependencies.h:19:10: fatal error: compilerSpecific.h: No existe el fichero o el directorio
 #include "compilerSpecific.h"
compilation terminated.
make: *** [Makefile:16: test_regDevWriteNumber.o] Error 1
Kiman
-----Original Message-----
Sent: Friday, November 08, 2019 5:46 PM
To: Ha, Kiman <[email protected]>; [email protected]; Zimoch Dirk (PSI) <[email protected]>
Cc: [email protected]
Subject: Re: Xilinx ARM64 mmap and regdev module compile error
Hi Kiman,
   You need memDisplay[1] in order to compile regdev[3] correctly.
   And there may be one more dependent module, symbolname [2]. Please look at
https://github.com/paulscherrerinstitute/memDisplay/blob/master/configure/RELEASE#L22
  However, symbolname doesn't have the standard EPICS building system.
   HTH
   Han
[1] https://github.com/paulscherrerinstitute/memDisplay
[2] https://github.com/paulscherrerinstitute/symbolname
[3] https://github.com/paulscherrerinstitute/regdev
On 11/8/19 7:52 PM, Ha, Kiman via Tech-talk wrote:
> Hi Dirk,
> I am trying to build a mmap & regdrv device support module for ARM64
> Debian10 and got some errors.
> It seems environment issue and needs additional modules?
> fpga@debian10-zcu102:~/iocApp/mmap$ make
> GNUmakefile:2: It seems you do not have the PSI build environment.
> Remove GNUmakefile.
> make -C O.linux-arm -f ../Makefile TOP=./.. \
>      T_A=linux-arm install
> make[1]: se entra en el directorio '/home/fpga/iocApp/mmap/O.linux-arm'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX
> -Dlinux     -g   -Wall           -fPIC -I. -I../O.Common -I. -I. -I..
> -I./../include/compiler/gcc -I./../include/os/Linux -I./../include
> -I/home/fpga/epics/base-3.16.2/include/compiler/gcc
> -I/home/fpga/epics/base-3.16.2/include           -c ../mmapDrv.c
> ../mmapDrv.c:9:10: fatal error: regDev.h: No existe el fichero o el
> directorio
> #include <regDev.h>
> make[1]: *** [/home/fpga/epics/base-3.16.2/configure/RULES_BUILD:235:
> mmapDrv.o] Error 1
> make[1]: se sale del directorio '/home/fpga/iocApp/mmap/O.linux-arm'
> make: *** [/home/fpga/epics/base-3.16.2/configure/RULES_ARCHS:58:
> install.linux-arm] Error 2
> fpga@debian10-zcu102:~/iocApp/regdev$ make
> If you are not using the PSI build environment, GNUmakefile can be removed.
> make[1]: se entra en el directorio '/home/fpga/iocApp/regdev/O.linux-arm'
> -I/home/fpga/epics/base-3.16.2/include           -MM -MF simRegDev.d
> ../simRegDev.c
> ../simRegDev.c:18:10: fatal error: memDisplay.h: No existe el fichero
> o el directorio
> #include "memDisplay.h"
> -I/home/fpga/epics/base-3.16.2/include           -MM -MF regDev.d
> ../regDev.c
> ../regDev.c:21:10: fatal error: memDisplay.h: No existe el fichero o
> el directorio
> -I/home/fpga/epics/base-3.16.2/include           -c ../regDev.c
> /home/fpga/epics/base-3.16.2/include/dbAccess.h:19,
>                   from ../regDev.c:10:
> /home/fpga/epics/base-3.16.2/include/dbBase.h:162:5: warning: 'rset'
> is deprecated [-Wdeprecated-declarations]
>       rset        *prset;
> /home/fpga/epics/base-3.16.2/include/dbBase.h:21,
>                   from
> /home/fpga/epics/base-3.16.2/include/recSup.h:67:8: note: declared
> here
> struct rset { /* record support entry table */
> /home/fpga/epics/base-3.16.2/include/dbAccess.h:23,
> /home/fpga/epics/base-3.16.2/include/dbAccessDefs.h:208:46: warning:
> 'rset' is deprecated [-Wdeprecated-declarations]
> epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
>                   from
> here
> el directorio
> regDev.o] Error 1
> make[1]: se sale del directorio '/home/fpga/iocApp/regdev/O.linux-arm'
Re: Xilinx ARM64 mmap and regdev module compile error Ralph Lange via Tech-talk
Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
Re: Xilinx ARM64 mmap and regdev module compile error Jeong Han Lee via Tech-talk
Prev: Re: Xilinx ARM64 mmap and regdev module compile error Jeong Han Lee via Tech-talk
Next: Re: I can't figure out how to change the rate guarantee... Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Next: Re: Xilinx ARM64 mmap and regdev module compile error Ralph Lange via Tech-talk
ANJ, 09 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
